Does that window even open?
Lots of pressure there.
Don't know yet. It ain't dry all the way. :D
It's "window and door" Great Stuff. I used it on two doors and the other window and they open and close just fine.
Not sure how I want to frame out this window though.
It's not complicated but I'm trying to picture how it'll look with the plywood on the wall. I want some kind of trim, but nothing fancy.
It's just cheaper to buy that stuff in the industrial 2-part box kits don't ya know.
At Menards, that's back by the paint section.
The problem with the cans is you have to wait until you have enough voids to fill to use up an entire can. Once you start dispensing it, you're committed to using the whole thing or wasting whatever you don't use.
I know nothing of the 2 part stuff other than its extremely expensive to use as insulation.
I use it to fill gaps.
The 2-part foam is what's used to seal rim joist on a house. One kit is enough to do a normal size house of about 1200-1600 SF.
Had it done by someone for us in Fargo when we lived there.
Did it in the house I bought for my ex. It was 28'x56'
Since it's 2-part, the chemicals Haven't combined to make the cleanup nightmare and it's mostly reusable except like the spray tip unless you get it really cleaned out good.
Well the majority of what I'm using it for us done.
Sealing the gaps between the lumber and the steel siding that are created by the corrugations. The whole ceiling perimeter is done. The 1-1/2" wide gaps between the posts and the steel at the ends of the pallet rack wall are filled. All that's left is about 20 feet along the bottoms of the walls I ain't gotten to yet. About 3 cans worth.
