Sarcastic remark goes here
How about now?Once I get my phone charged to 100% I'm going to head out and tackle the wheel hardware. I need to run my earbuds with music to tolerate the noise of the compressor and generator.
Yep it's a slow process because of my less than awesome air but I have 6 studs in so far.How about now?![]()
It's going better than the one I replaced before since the regulator is gone, but I can't quite fully seat a stud on one tank.
One wheel is done. Finally.
Yeah it takes ages. The impact wrenches themselves are really good. When the tank is full they hit hard and fast. But it isn't long before they don't have anything left.Yeah, go I'd go ahead and get that air compressor.![]()
I know exactly what you mean. There are huge differences between what I can do when I'm wide awake and full of energy and what I can do at the end of the day.I started on another but when I'm even slightly tired I can't move these tires and brake drums. I know when I'm licked and better off.
don't forget the PSI needed to work those air tools. even though many run at 90PSI, how long can they run? i had a typical 90 PSI, 400 torque impact gun. i still have a small air compressor, it only takes like maybe 2 blasts of the trigger and it's kaput. ypu have to also factor in the CFM (cubic feet per minute) any air tool uses.Anyone know if runtime is linear with tank size? Would 80 gallons give me 4x the runtime of 20 or doesn't it quite work that way?
Yeah my half inch has an 8 CFM draw vs 12 for the bigger 1" gun and 11 of the pistol style.don't forget the PSI needed to work those air tools. even though many run at 90PSI, how long can they run? i had a typical 90 PSI, 400 torque impact gun. i still have a small air compressor, it only takes like maybe 2 blasts of the trigger and it's kaput. ypu have to also factor in the CFM (cubic feet per minute) any air tool uses.
in my former shop, i had well over a 100 gallon tank ( i think it was a 150 gallon tank) , and the impact tools ran like almost forever.
It's linear.Anyone know if runtime is linear with tank size? Would 80 gallons give me 4x the runtime of 20 or doesn't it quite work that way?
If you're having to hammer on these things with an impact to get them seated how do you know you're not stretching them?Yeah my half inch has an 8 CFM draw vs 12 for the bigger 1" gun and 11 of the pistol style.
I had no issues taking all 10 outer nuts off without waiting and then by the time I got the outer wheel off and out of the way, zipping the inner 10 off.
I ran into major issues pulling the studs in, and I'm thinking it's probably my stupidity trying to cheap out using a nut that's relatively soft. Wasting power overcoming friction.
The Lisle supposedly has a bearing in it so it can keep turning.
I have to assume I'm not based on them still moving but slow.If you're having to hammer on these things with an impact to get them seated how do you know you're not stretching them?
We still talking about wheel studs?In case you're wondering, I have enough sense to watch it draw in and stop hammering once the gap closes.
Ask me again later tonight.We still talking about wheel studs?![]()
and later, it'll still be about wheel studs...Ask me again later tonight.
