When it's turned off and completely drained of pressure.
Think of it as water instead of air. Water won't compress. A 21 gallon air tank is also a 21 gallon water tank if that's what you fill it with.
The CFM rating is different though. It's referring to compressed air. That's why there's a psi associated with it.
(A little 75 watt bedroom pedestal fan might move hundreds of CFM but at almost zero psi.)
It gets complicated trying to figure out how many cubic feet of air is packed into a tank when the pressure is 90 psi.
To do the math you gotta start with 14.7 as "zero" because the air around you that you're breathing is already compressed to 14.7 psi. (Zero if you're in outer space without a suit)
There's a formula called Boyle's Law but it requires algebra
Yeah the PSI part complicates it and I do know I can't just hammer away for 14 solid seconds, but it does seem like I can get 14 seconds worth of bursts and get the same or nearly the same performance before it drops too low.
If I watch the gauge on the regulator while I'm pulling the trigger, I can pop it for a couple seconds and watch it go down. As soon as I let off, the gauge bounces back up. How far it bounces back depends how long I've held the trigger. I can get about 3-5 or maybe a few more of these short bursts before the compressor kicks back on. It may not be full power every time but they feel pretty similar.
But yeah some day I'll have one of those 20-30CFM compressors to run everything quicker. The process I have to go through is tedious and best. It takes forever, but for now it works.
back in the day, MAC, SNAP-ON did not make thier own air tools. in fact, all the tool trucks ever had were CP air tools..i had a few SNAP-ON and MAC air tools in the going years, but they were crap. Chicago Pneumatic, i think sold out and this is when they started going downhill for reliability and torque.
Chicago Pneumatic was bought by Atlas Copco in 1987. Atlas Copco is Swedish and has a small plant around here that was split out into a company called Epiroc.
That's because you're drawing air faster than the regulator can allow it to flow.
I run mine straight from the tank. I do have a regulator plumbed up but I don't use it.
I figured that but didn't know the cause. It has to refill the hose each time.
I might replace it since it's pretty old and didn't look real nice inside when I had it apart. A new one might perform a little better.
Are you on a V with one being straight hose and the other being the regulator?
Checked the torque (and the new impact gun) on my drives and spun two more studs loose.
They're all getting replaced as soon as the hardware arrives. Wheel studs, inner cap nuts, and outer cap nuts x 40.
I'm not pissed since it's a 32 year old truck but I'm also not willing to risk a wheel coming off.
As a side note, the 1" pistol style gun was a good purchase since it's MUCH easier to work with with the torque stick attached.
I probably don't need the other one anymore but it's going to remain available for the big hits.
You really don't want a wheel separation if you own the truck and was last one that was working on the wheels.
You obviously are aware of this information but, it takes longer to delete a post than it does to hit post reply.
So this will be right here. ;)
Lol. Agreed. I can't play dumb anymore.
I can actually be dumb, but the courts won't let me off the hook for that.
As much as I hate debt, I'm thinking about putting a 60-80 gallon compressor on my Tractor Supply card @ 3.99%
I can get the torque I need out of my little one but it's gonna be reeeeeally tedious to do all 120 fasteners on this truck with it because of all the cycling.
One wheel isn't so bad but I also only drew one stud in last time.
I keep checking this thread to see if a trailer has been spotted behind that red truck.
drama cooking GIF
We may have to send someone to his house to gently encourage him with a cattle prod. 😁
Save me money from paying Mistress Pain. 🤤
I took my regulator off, by the way. It was definitely a restriction. Now my flow is more continuous and I can run longer bursts.
I can't do anything about the 1/4" ports on the switch but it's much better.
Once I get my phone charged to 100% I'm going to head out and tackle the wheel hardware. I need to run my earbuds with music to tolerate the noise of the compressor and generator.
