Gee I never thought of that.
th
Seems like I told you to do that several pages back.
Yeah your suggestion does seem most plausible at this point. Until last week I had no way to implement it.
Here's hoping it's tolerable until revenue comes in for new tires AND wheels. I'm not putting fresh rubber on these janky things. And these tires have so much meat I'd hate to get rid of them... especially if it turns out it ISN'T the tires.
I still believe that violent shake is something different. I've noticed more that it seems worse when it comes off throttle...slowing down into the speed range is worse than speeding up into it. So it seems like it might be a dynamic forces issue. Makes me wonder if it's the front spring shackle bushings. Like they're shaking under the weight transfer or something.
Don't know if a trailer holding the rear end down would reduce that or not. Doesn't feel like rear end hop the way you get when you slam the brakes bobtail. And it's not my brakes. It does it just letting off the throttle.
Maybe I need to take a look at those bearings. I trusted the shop's inspection, but maybe I shouldn't have.
I doubt that’s it, but you can remove the rear shaft and take it down the road.
Yeah it's not. I looked close at both and you can see the shiny metal. That means they're sliding nicely. The guy who had the issue, his was rusted to hell and back.
Pumped some grease in there anyway since I was already under.
Just trying not to overlook anything. Sometimes it's something you wouldn't think is related that gets you.
Like maybe the vibrations will go away if I keep my coffee in the OTHER cupholder. 😃
So I revisited the right height thing. Pushed the bar into each end as far as it would go. Looks more level and rides better. A lot of the shaking is gone too.
It didn't seem to help last time but the tires not being swapped yet probably masked it.
I believe it's gonna be tolerable until I have eleventy billion dollars.
Hopefully the other guys will correct me if I'm wrong, but one thing I've always noticed is that the top of a truck's frame is usually flush with the tops of the drive tires or within an inch.
Yours looked low in that picture with the wheels off but I assumed you had the air dumped.
Yeah there was no air in the bags when I was working on it.
It actually seemed to ride too high. I got it down to where the frame at both axles is basically in line with where the tread mates with the carcass of the tire.
Every time you crank that truck over, its one revolution closer to a catastrophic metal fatigue failure. Yes, you can say that about any truck, but old ones are much closer to it than any newer truck. Plus you've got all the downside of a mechanical engine. Upside, you're only into it for what, about $15k? I do hope it lasts.
Obviously not my choice of how to truck. Go make some money.
If his truck has 1 million miles and has always had premium fluids and maintenance. A new truck has 100K miles and still running the factory fluids then I guarantee you that new truck is much closer to catastrophic engine failure than the million mile truck.
