I found a math brain cell on life support. It had enough energy to realize that the pythagorean theorem can be used here.
a²+b²=c²
A=kingpin to FOT
B=half of trailer width (or kingpin to side of trailer)
C=kingpin to COT
Swing loss is the difference between the kingpin to FOT and kingpin to COT.
Based on 36" from kingpin to FOT and 51" from kingpin to side of trailer (102" ÷ 2)....
36²+51²=3897 so √3897 (c) is approximately 62.43 or let's just say 63 inches. 63-36=27 or 2 feet 3 inches. Normally you would round down but you can't when talking about hitting things.
So when you swing a standard trailer you need 2 feet 3 inches of clearance as measured from FOT in a straight ahead position.
a²+b²=c²
A=kingpin to FOT
C=kingpin to COT
th
a²+b²=c²
A=kingpin to FOT
C=kingpin to COT
Thats enough profanity.
Calm yourself.
a²+b²=c²
A=kingpin to FOT
C=kingpin to COT
or you could look at what you are doing
It's most likely to get relocated if/when I pull the deck plate off to either refurbish or replace it anyway. At the very least, if it needs cut out it's gonna get welded back in turned sideways so it's parallel to the back wall of the cab/toolbox and not just sticking out there like an appendage of reproductive purposes.
What is the fitting for? A dump trailer?
Not sure what they used it for but I put a new fitting on it for air tools. I could take some of that shit off since it's really just a mess of old fittings and a chuck and such but I'd have to go buy the right step down to come straight off the big pipe and I haven't really been in the mood.
Make oiling that coupler part of your regular maintenance. The little balls inside will rust up quickly on a truck, and the brass parts might even seize.
Just a quick squirt with WaterDisplacement 40. Or air tool oil if you've got it out. Every time it rains.
There's a reason why they made glad hands such a simple device with no moving parts.
Yeah I know. The old one was seized and so is the one (not mine) still on there.
So I fixed my f up and spun the tires for access to the valve stems. I think that was harder than getting them on the hub in the first place. :rolleyes::D
Anyway, took it for a spin and the shaking changed as far as speed and duration again. I think. Unless it's all just made me looney at this point.
Either way I'm thinking it IS most likely in my tires and/or rims. So I'm just gonna have to run it and see if it works itself out with a trailer pressing down on it and highway miles chewing some layers off.
Can't you let them all down to like 15 psi and bobtail around for a bit? 🤔
Seems like I told you to do that several pages back.
