According to El Goog, this happens when the fuel nozzle goes bad. I'm settled in for the day after working late but after I get some sleep I'll take a look at it. Apparently it's supposed to be replaced every year. I'll try to clean it first.
Maybe that's what's wrong with mine.
Mine actually seemed to improve a bit after I ran it a few hours when I was building my shop, until I got the gas furnace installed. Kerosene tends to clean stuff.
Maybe you should try running regular kerosene through yours instead of diesel.
I might do that. It's certainly easier. I have some of that diesel treatment too. Forget the name but it's famous. Might try some since there's still half a tank left.
I'd just dump that fuel in the truck and put kerosene in it now.
Surely you can invent a reason to heat the shop today and run some kerosene through it.
And you can bobtail the Ford to go get the kerosene. 😊
Damn and I thought wheeling some bolts was a stupid waste of effort. 😂
It was. I'd have replaced them. They're just bolts.
I built myself my own little hardware store nuts and bolts organizer thing a few years ago. I have pretty much every length of and every size for 1/4, 5/16", 3/8" and 1/2" thread sizes plus all the nuts, lock nuts, flat, split, fender and flat washers. Everything in grade 5.
So replacing hardware usually doesn't require a trip into town.
If I didn't have all that, then I'd have done what you did and wire wheel the old ones. They look like they cleaned up nicely. I'd definitely use anti-seize on them though, especially due to their location and the fact you'll probably be running the Pennsylvania Salt Pike.
Oh and that washer fluid reservoir,.. Is there room for a 15 gallon tank under the hood?
I used to use up a whole gallon just one trip from Ohio to Breezewood if it's snowing because they dump so much salt.
Sad part is the hardware store was across the street from where I got the air grinder and is where I got the chain. So I could have and should have but still didn't. Lol.
It was hella relaxing to do with my earbuds in as hearing protection, listening to my old tunes.
I consider it to be one of those things like collecting stamps.
Wick lanterns will burn diesel, kinda ill advised tho cuz of all the additives and shit in it. Kerosene’s better
Friggin wind sucks. But this is where I'm at as of last night. I may need to get a torque multiplier or just suck it up and get a bigger compressor.
My generator does do 240V. Just need the right plug.
Your generator has two separate hots. That's why there are two breakers and two sets of 120 outlets.
Even if it didn't have the 240 outlet, you can.... improvise 😎... with two power cords. That's how I was able to run a 240 volt electric heater in my camper.
Yeah I'm not as redneck as you. Lol.
But knowing that it can run it, I'll get a compressor somewhere.
I thought it could then I was like no wait it can't and now I'm like oh yeah it can again. I dunno what made me think it couldn't.
I'd have had one like a year ago if I hadn't thought it wouldn't run it.
I just don't want to wire up this old shit garage for 220 when I have every intention of tearing it down if I can get away with not doing it. I'd rather run my gas every so often.
Does your garage have its own panel or box? If so, post a picture of it. You might be able to do 240 easily and cheaply. Good enough to run a compressor anyway
As for your generator powering it, you need to consider the compressor motor's momentary starting draw and your compressor's surge capacity.
I don't know what mine draws but it doesn't dim the lights when it starts up, so it might have a capacitor start.
Nope. Idiots just ran a junction from the house. It barely powers the single LED bulb in the ceiling.
My dad and I tried to run 220 out. He usually knows what he's doing but it didn't work. I was tired that day after work and it pissed me off so I said fuck it I'll use the generator and have a professional do it when the new garage is built.
And no I'm not trying again.
A ~17 amp compressor would be fine. I'm not looking at those horizontal hippo units.
Dunno why it wouldnt work. Last time I did that I just stuck a 100 amp breaker in the house panel and ran the right size wire out to the sub in the garage
Why not just get a gas powered compressor? That what I’ve got on my service truck.
Got a torque multiplier coming via eBay. Dunno if it'll be a quality tool but for $36 it's worth a shot. Coming from NJ next door so it shouldn't take long to get here.
I'm just thinking as nice as a big compressor would be, I kind of only need it for the lugs right now. And that's a lot of money to spend for some lug nuts.
If I can get them broke loose and then check them on occasion as part of my maintenance, I probably won't need a big compressor until I go to take the suspension apart to rebush it. And maybe not even then.
I'm really just having trouble because they were run on too tight and haven't been off in ages.
