I'll need a tube to receive the old bushing for removal and get a set of washers to fit for pushing them out if the ones I have are too small, but I have everything together for installation (I think).
I can use the installation washers from the transverse beam to act as the pushers for install.
The dedicated tool is so simple and basic there's no freaking way it's worth the $700-800 they want. Other than the tube it's pretty much what you see here that cost me $35 at Tractor Supply.
The big black washers were expensive as shit at $60 each but they're for the truck not just a puller. I figured they can play double duty until I put the rear together since they go on last.
$60 for two rubber washers? 🤔
Back in the 90's I had this dirt bike. 1981 Kawasaki KX80. Fast bike for a kid. It's top speed was 60 mph but it would get there in like half a second. It was like hitting a governor. Weird.
Anyway it's exhaust pipe had an O-ring that sealed it up where it plugs into the cylinder.
Occasionally it would break and the bike wouldn't have as much power. Tuned exhaust back pressure is very important for a 2 cycle.
Honda wanted like $12 if I remember it right.
Ace Hardware had the exact same size o-ring for 39 cents. I'd buy several at a time.
$60 each and they're not rubber.
But yeah now that I know exactly what they are I can have some made. They're big bastards like 4" in diameter.
You spent $60 on a steel washer? 😂
th
Yeah Neway parts are stupid. It calls for 4. I bought two to see what they are first.
I consider suspensions kind of a big deal and won't just throw anything together.
Well what's the explanation for why it's $60?
Is it super ultra high grade crane boom tool grade steel, ground down to specs so precise NASA engineers are called out to calibrate the equipment?
Got the truck blocked up to swap the outer drive tire positions front to rear and see if it rides any better.
The reason for the chain was to secure the front axle so it would lift along with the rear. It worked as expected.
Running out of air quickly though. One passenger side tire is off and to the side but the other doesn't wanna break free. I'm sure I'll eventually get it but it takes a lot of patience waiting for the itty bitty compressor to cycle.
Definitely looking forward to the day I have a bigger one installed. I won't be able to wait until a shop is built.
Got the torpedo heater working again. But it won't run right with the lid on. Just like my Dad's. I dunno why they get that way after a while. Maybe the motor is overheating. I'm not buying a new one for it. Screw that noise. It works fine without the lid. So my garage will at least have heat this winter.
Puttered around finally fixing fitting leaks on my air tools. Basically just needed thread dope. Need more quick connects. Got a buttload of 1/4" but swapping out 3/8" all the time gets old. Especially now that I've doped them properly. Better to have them on everything and sealed.
Pretty much called it a night after that. Didn't get all the lugs off. 37°F is too cold to be working outside more than a few hours. And too much impact hammering does hurt my shoulder.
Mine is this yellow pro temp thing. 125k btu or something like that.
Sometimes it won't light unless I hold my finger over this suction hole thingy on the back, or tap it on and off while it's trying to light. It's like a choke.
There's an adjustment screw but turning it doesn't help.
I played with the adjustment screw and it makes a difference. It's just fuel delivery though. You can go all the way from starving it to flooding it. But there is no right setting with the lid on.
I can take the lid off, fire it up, set the lid on, and the flame reduces, it dies, and puffs. It puffs so bad I need to open the doors for the air to flow through and get it out. My eyes are still burning from it.
Lid off, no smoke, full strong flame, runs like it did when it was new (and it's only a couple years old). The only smoke is the tiny poof when it first starts because it's diesel and there's nothing when I turn it off.
So yeah I dunno. I'm just leaving the lid off.
Yeah I guess it just makes sense just to leave the top off.
Sounds like it ain't pulling enough air with the lid on though.
According to El Goog, this happens when the fuel nozzle goes bad. I'm settled in for the day after working late but after I get some sleep I'll take a look at it. Apparently it's supposed to be replaced every year. I'll try to clean it first.
