Had to dick around with a trailer today. Pulled it from the rail, bill said it was shy of 39k. The air bags didn't read heavy enough and I thought it was a little odd. Then I got on the interstate and BUCKING BRONCO! I pulled off to the TA and it scaled over 36k on the trailer and only 24k on my drives. No freaking wonder. I moved it a total of 9 holes to get it legal. It was still lighter than I'd want on my drives but at least I got through the scale house okay. I would have run out of holes before it was evened out, so I figured I'd make it no longer than necessary instead and tolerate the ride. It still bucked but not nearly as bad. I couldn't wait to get rid of it though.
Strange deal today. My sole purpose was to take an empty to a small place in Preston MD to start a drop and hook pool.
I get down there and they had no idea what I was talking about. He called another guy at a different site and he didn't know either. I got there right at lunch so he said give me 30 minutes and I'll talk to my boss and call you. So I waited the half hour. Heard nothing. Went back inside and he said his boss hasn't gotten back to him yet. I say okay fine and give them another half an hour. Still nothing. I call dispatch and she says if you want to wait longer you can otherwise just leave. They should know about this.
Another guy came in behind me to drop a 2nd trailer. He went inside when I was waiting in my sleeper and they told him the same thing.
I got paid to bring the empty back but still.
Other than that it was a decent run. The eastern shore is nice trucking. I was sort of looking forward to picking up from there. So was the other guy. We kinda get stuck doing the same stuff as locals and sometimes you want something fresh.
That's not a good way to start for their company.
If that is the way they operate not knowing what is going on I imagine it will be a nightmare of pre-loaded trailers not being pre-loaded.
I could be wrong. Maybe the will unfuck themselves and get thier poop in a group.
Yeah it was weird they let us inside and the place was almost completely empty. So I don't even know what would have been loaded. There was only one guy in there that I saw and the other driver said he saw 2.
Maybe it's a deep state thing and now I'm going to be offed for talking about what I saw.
Finally started making some real effort to get the old wagon to run good enough to get it on the tow dolly to scrap it. We can push it on but it's a lot easier to just drive it.
I don't remember exactly why I parked it but I know it has a fuel leak at the filler neck or the tank itself. I never got up under to truly see what's going on. Also the battery is dead as a doornail and is why it keeps shutting off when you hit the brake pedal to put it in gear. The alternator is good enough to let it idle and rev up but as soon as you hit that pedal it dies. It moves just fine if I keep it tethered to the pickup with jumper cables. That tells me there aren't any mechanical issues with it.
A little while back I got one of those Noco chargers with a repair mode for sulfation. I have the battery in the house on it to see if it can help.
I'm not in a time crunch to get rid of the car, but it's in the way of my plans to clean up, expand, and organize my parking at the back of the property.
Noco did a good job resurrecting the battery. It's back in the car and starts and moves. Took the opportunity to mow where it sat then put it closer to the shared alley to make it easier to maneuver to the tow dolly.
I wish I had paid more attention to the tires the dealer swapped onto my truck from the other truck. They all had better tread than what this one originally had, and that's all I really cared about at the time.
Now I'm seeing chunks of tread missing from the passenger rear set and have always seen cupping on the driver front set.
I don't know if it's my truck, or the tires already being that way and getting worse over time.
The one with the most chunks missing also lost all air pressure and dang near came off on me a couple months ago. Whatever that's worth.
I'm thinking I'll do a swap job because the passenger front still look good and the driver rear still look good. Put the good ones on one axle and then toss the bad ones and get new for one axle only.
It's hard to judge wear or diagnose a truck defect when the tires aren't original to the truck.
Drive it to the junk yard. Be a man. Ask yourself what would @Duck do.
I dunno..
Blueford just spend two MF'n weeks in the hospital for a damn master cylinder.
It's the easiest thing to swap out, but it takes two people to bleed them afterwards and my dad is too dumb to help.
Damn thing stops quickly now.
Just gotta get plates and insurance and stuff and it'll be my daily driver.
Oh and change the oil, which I don't feel like doing right now.
Gotta do something about the slop in the steering gearbox and maybe new shocks or something.
Taildragger airplanes probably have better handling on the ground than this old thing.
I dunno..
I mostly meant the part where you say fuck it send it when you've decided it's got to go.
I already got a ticket for an expired plate on it once. I ain't doing that again. šŸ˜‚
I sold mine but my dad still has his tow dolly so it's easy enough to drive it up on, strap it down and sayonara.
We don't have stickers or front plates which means the pig gotta run you down and do something on his computer. I'm guessing a lot of times that's just too much effort, or at least more effort than running a radar gun to do your road piracy.
They got automatic plate readers these days. I got busted on the turnpike. My inspection was good but it was out of sync with my plate so I forgot. Cost me 200 bucks.
I ran all the way to near Pittsburgh to look at a semi truck using US 30 and side roads without an issue but dumb me decided I wanted to get home pronto despite the tolls. šŸ™„
We really are heading toward 1984.
For sure. I also got busted in PA for not having a PA inspection sticker on my windshield despite having a recent DOT inspection sticker. Was placed out of service and had to get towed to a shop to get an inspection sticker.
The cop inspected the truck and found nothing wrong, even complimented me on my maintenance.
But no windshield sticker = OOS.
It was when I got my authority and forgot that I switched from Indiana plates to PA plates.
That lack of a sticker cost me about $700 all in. It's dumb.
The only upside is they couldn't report it as a DOT OOS because it's a state specific thing. So it's not on my saferweb profile.
He could like I dunno NOT be a cunt but that's usually too much to ask in that part of the country. I had one in a scale in Ontario waste a good couple HOURS of my time because the boss hadn't signed the registration for the truck.
To make it worse this wasn't long after everyone went through the scramble and panic to get on elogs because of the mandate in the states.
Even better was the one in NY that wrote me a "fix it ticket" for KPRA on a fixed axle tridem. How do you FIX that exactly? By his logic nobody can run a tridem in New York. They laughed when I brought that one in the office. Couldn't tell you how that worked out.
