They used to sell grease pack. Small plastic packs filled with grease. You would drop them on the fifth wheel, dump the air , back under the trailer and raise the air again and they would go splat. Fifth wheel greased.
Not sure if they still have them.
Like a ketchup pack? I heard of those.
You got me thinking. Maybe I should try ketchup.
I just have a fundamental problem with these tiny plastic packets being wherever.
They still make them. My replacement uses them on his 5th wheel. I told him to get a Teflon pad since he rarely drops the trailer. No grease oozing out all over the place and making a big mess.
I have driven trucks that have automatic greasing systems. Our shunt trucks have automatic greasing systems. Not sure why we are giving away free grease, considering we are only hooked for a few minutes. :dunno:
But when they were setting up the automatic greasing systems, I saw part of how they did it and basically it is running lines from the grease can to the grease points (nipples). I am not a Chamanic but I am sure even I could do it.
You can also set how often it dispenses grease.
Pretty labor intensive to set up but, worry free afterward. Just make sure the canister has grease. Even if the canister runs dry, there is no harm. They only fill ours once a month when they are doing a service on the truck.
That's probably something I'll look into considering how many trailers I hook.
You should see the 5th wheels of the can haulers around here. They haven't seen grease since Moses was a baby. That has to be like driving a straight truck with no articulation point.
Makes sense.
If he's anything like me, he's not buying one specifically because you told him to.
Absolutely not. I never knew they existed until I saw him use one and questioned it. I gave him a trailer with a grease free, like brand new pad on it. He put about 3 pounds of grease on it the first time. Whatever! I don't have to clean it.
So I got super late started yesterday and it took me into the wee hours of this morning to get back home and parked. I'm still getting used to these 12+ hour days. Ironically it's not that I'm super tired and need extra sleep, it's that I'm NOT super tired so it takes me forever to get wound down then finally sleep.
I totally get how a guy OTR would be like why can't I drive for another 2-4 hours, stupid ELD. I could never comprehend that before.
Anyway, it was another longer day going down and back twice. I had a pickup the first time but only brought an empty back on the second one. I would have preferred a load for the extra weight in the winds and the cash in my pocket but it did help me make up some of the bad fuel mileage.
I'm taking off until Monday to get a 34+ in because I have some stuff to do, but Monday is already setup as more of the same. Down and back twice. For now it's empties back both times but that could change. You can't really count on it though.
I feel blessed enough being able to get deliveries and pickups from the same place with even this much regularity. Or at all really. It's always awesome to get a return load by simply going to the back side of the building.
As far as revenue goes, I grossed the same this week on 5 days as I did 2 weeks ago on 7. I committed to fewer, longer days instead of more short ones. Last week doesn't really count since I had to take Thursday off for my DOT Physical/Med card and it took until Monday morning to get it confirmed. So I didn't make much for the week on those 3 days. Got a little deposited into the bank for it but nothing to write home about.
Did you receive confirmation in the mail?
Went outside earlier today and adjusted the steering box on the pickup. Went to start it to see how it feels and....nothing. No crank no start.
My little dinky charger is for cars and isn't doing a lick and for whatever reason I couldn't get a boost off the Mack.
So I got one of those 3000a portable boosters on the way to see if this thing has any life whatsoever.
Tried tapping the starter with a hammer and that did nothing. Tapped the starter relay with a wrench and that did nothing.
Wires look fine. I don't see anything obvious that simply fell off, broke, or came loose.
Wasn't even a day or two ago that I last drove it.
I really didn't take two days off only to have to work on the truck out in the yard in the cold. I wanted to get groceries and rest up.
I know I JUST got rid of the Honda but if I knew I'd be working again that soon after I did, I wouldn't have. So I'm probably going to be looking at a newer car. Again.
