Differing rules here. When the physician completes your physical, he must enter it into the system before you can leave his office. You then leave with your card in hand. BUT... you then have to to the HSMV website for the state of Florida and do a 'self-certify'. All information entered online has to match what is on the card and form that you have to submit to the employer.
They recently just changed the rules for the physical too. Even if you are not gainfully employed and hold a CDL, you have to get the physical done on your own dime and do the self-certify. A DOT physical is now $250. If they come for me, I'll just go to an operators license. I'm not going to give these thieves that kind of money every year for nothing.
Since I retired I have found a place that charges $85 a year. I can live with that.
I thought that I lived in BFE Florida. Parrish Medical which has the market cornered here insists on raping everyone.
Even the thought of ever getting into the drivers seat of another truck today is nauseating.
Best Buy had a new smart TV that fits in the Mack for $60 so I went and got one. I also found a TV install kit in the truck and it had the screws and washers.
Truck has an antenna somewhere. I plugged in the coax and got 22 OTA channels.
I just came in the house after about 3 hours relaxing in the truck for no particular reason.
The TV isn't the best but it'll do. It's only 720p but you can't really tell unless you get right up on it. Streaming 720p content is easier on the phone as a hotspot anyway so it's totally fine.
The colors are a little off compared to a good TV like I have in the house but it only matters if you know any better. You can adjust it some but the options are limited.
It gets plenty loud over the APU generator, which is well muffled by the truck's insulation in the first place.
It also doesn't weigh much of anything so it shouldn't stress the mount or itself very much. The only way it's coming down is if the TV chassis itself is built so cheaply that it splits apart.
I obviously haven't been able to give it the rough road/expansion joint test yet but so far for 60 bucks I'm very pleased with it.
First off, get your damned dirty boot off of the sheets! I had to do that.
It may have the capability for multiple market scans. What you get at home may be able to be saved and the scan you do in Upper Marlboro is going to have many more channels. It's just a bigger market.
The antenna may be mounted in the sleeper ceiling. Less drag and all that.
It's a brand new mattress with the plastic still on it. My boots are actually on that part. But yah I get it. I wasn't even planning to relax in there.
I'm curious to see what it pulls in elsewhere. Most of my 20 local channels are bogus junk but there are a couple gems I could fall asleep to.
I was reading somewhere that it could be the same one they used for the radio, which is on the passenger mirror. It's a short little stub. The CB antenna is on the driver mirror. My day cab had dual CB antennas on the mirrors. The radio also pulls in a crap load more than the day cab ever did, and it's on the roof. The CB also already works good enough to not mess with it.
You took the words really out of my mouth.
The swing arm lets you bring it out closer if you want.
That picture reminded me of something I don't know if you're aware of since you've always been a day cabber...
When you're at a truck stop, sitting around waiting out a ten hour break or something, avoid sitting in the drivers seat.
Bums & diseased whores are more likely to bother you if they can see you're awake.
That sounds like a pretty good tip. My dad and I both got propositioned back in like 2001 by a hooker at a truck stop when we were sitting in his cab.
Other than the TV I've been shamefully lazy this past couple days.
I broke the cycle today by replacing the side mirrors on the pickup. I had modified the doors to take a new style mirror but unfortunately they're a cheap POS that doesn't last. The glass gets messed up in one way or another over a short time and the arms rust.
I'm thinking I might have some mirror glass cut to shape from a good supplier for next time. There's no concave or convex, it's just a simple flat slab on each side.
I can live with the rust until the truck gets a paint job. I just can't live with not being able to see.
Decided to try sleeping in the truck tonight. No particular reason since I'm at home. Just wanna try it before I have to do it. Don't worry I wore my slippers and took them off before I crawled into bed.
That's a good idea to get used to sleeping in the truck. When I was OTR and was in the yard for a 10 hour break I would sleep in the truck even though the drive home was only 15 mins. I was just that comfortable with sleeping in the truck.
I know you are not planning on living in the truck but just as a sidebar, when i would go home to sleep I would wake up in a panic wondering where in the hell I was. 🤣
I did that sometimes when I was regional at Schneider. I could have gone home on like a random Wednesday but I stayed in the truck at the yard anyway.
This truck is way cozier because the Schneider sleepers were almost like a coffin sleeper by comparison.
Trucks seem to be designed for you to lay with your head on the driver's side.
But if the truck isn't on level ground, sometimes I'd have to switch. I can't sleep if my feet are higher than my head.
Don't need to bring a level though. Just lay down and you'll be able to tell.
If the lean is so slight you can't tell, then it doesn't matter anyway. 😅
