Ohh you know it's just a matter of time.
I got lucky when I did P&D all day in the inner city. But I did have a lot of TL loads also.
Hey one more question about the rail yards. How does the BOL's work?
Is it more actual paper and signing or tablet and entering with digital signatures ?
We get our BOLs through the company app.
Parked in a spot down at the regular customer for the first time today. It went as smooth if not smoother than with the day cab. Had to do a minor pull up correction but that was it.
In and out picking up a load from around the back of the building in 15 minutes. The other 10 minutes was guard shack check in/check out time then I had to sit for 5 minutes to complete my 30. Didn't really need it legally but the company likes to see it so it's whatever.
Original plan was back with an empty but the after hours support called me when I was on my way down and asked if I wanted a load.
Heck yes I want a load it's the same effort except $100 extra pay.
Also 7.7mpg on the day running anywhere between 65 and 72mph as the mood hit. The tank overall showed 7.9 by the end, and as much as 8.1 for a little while.
Sometimes I'd pace someone sometimes I'd pass. No particular rhyme or reason.
I'll be super happy once my fridge, microwave, and TV are in this thing so I can be supremely chill.
Like the Beastie Boys say, chillin' the most!
Got a nice early start. Left the house around 4:30am.
I'm figuring I'll get out of my first stop around 7:45 and then by the time I'm near Richmond VA for stop #2 it'll be well into mid morning and traffic will be less of a nightmare.
Got to Richmond at quarter after 10. Apparently I missed getting my paperwork by a couple minutes. By the time I dropped and hooked it was after 10:30 when they go on break.
Having the sleeper is nice for this. Need to get my butt in gear and put the fridge in and buy a microwave. Would be nice to eat a hot meal right about now.
Dropped my phone. Cracked the screen bigly.
Hmm. I'm wondering why I have never cracked a screen on any of my phones. Ever!
Like you said, I've had my share of dropsies over the years too.
Remember the earlier days where you drop your phone and the back goes flying one way the battery goes flying the other way from the main unit .
I think it comes down to what type of case you ultimately choose.
Some people are minimalist not wanting anything to bulky or military like.
Me thinks it's those people who through multitudes of dropsies that the phone get a hairline fracture to tiny to detect except for the next "hard knocks"
This time it happened to land on the edge so it split the screen.
Got my ass kicked on the way back. Either the chassis was junk, the load wasn't even, or the wind itself took it out of me. Maybe all of the above.
This truck is usually like a Cadillac but my shoulder and neck are so sore I'm having to take tomorrow off, because it would have been the same run again.
I don't have any issues with the run itself in principle but I can't back to back that experience. At least not yet. I was off for waaaaaaaaay too long.
The wind was so bad I only got 6.8 on my day when any other time I'd be easily in the 7s.
Traffic worked out as I expected though. Pretty much smooth sailing.
I should see about getting a sleeper installed on my shunt truck. :D
Instead of off today, change of plans. Tomorrow's load is here and there's a pickup also ready so I'll be paid loaded both ways. And she's got an Upper Marlboro MD run loaded both ways originally also for tomorrow that isn't ready until tomorrow.
Instead of hustling one long ass day tomorrow I'm running what's here this evening. Then I'll have more hours for traffic to and from UM.
Also I did finally buy a microwave but instead of going to get it I'm letting Walmart put it on my porch. Supposedly it'll be here todsy.
I'm not waiting around for it since I don't need it yet. I would want it if I was cramming both runs into tomorrow. I'd want my fridge in too.
I did get a comforter and big pillow this morning. So I can sleep in there if I need to.
I'd prefer it to be decked out for max comfort first though.
Oh yeah I *need* to get a small coffee maker too.
Fridge and microwave are in. I pulled a dumb dumb and blew the fridge fuse. Can't for the life of me locate the entire box of mini fuses I bought a while back.
I know I have two huge assortment packs for both sizes of fuses. I used to keep them in the day cab, but they aren't in there anymore. They don't seem to be with all the junk I removed from the truck either.
I had a single serve coffee maker that came with a travel mug, It was only like 14 or 16 ounce. It did the job and it also could make tea in the basket. It was pretty quick at heating the water and drip brewing.
Bit of a moment and thought what if I was actually a responsible person and put the fuses somewhere that I'd actually find them to use with other vehicles.
Sure enough, they were on a shelf in my garage.
So not only are they in the junk drawer of the semi for it, I have a fresh new 15A in the fridge slot of the bunk's fuse panel and it's operational.
Its an ugly install. I took the factory bezel off the shelving and slid it in the hole. Then I cut away the plastic that was hindering clearance for the door to open. I did not reinstall the bezel. It would not let the fridge door clear unless I also chopped it up.
I'm not super concerned with appearances at this point.
As far as the factory wiring goes, I chopped off the proprietary end and put a male & female plug on each set of leads. I still wanted to be able to unplug it easily. I accidentally got the new leads together for the truck side and that's when I blew the fuse. Oops.
These are the plugs I ended up using. They're cheap and common and I got a 10 pack. The wires are the same gauge as the fridge so I figured they're good enough.
That sounds about perfect. I don't need 10 cups at a time. I don't even make 10 cups in my 10 cup coffee maker at home. Most I ever made in that thing was the 8 cups (travel mugs) for the two Mennonite guys who did my roof and my dad and myself. That was a huge brew.
Fridge is currently showing 8°F and 44°F on the display. Time will tell if it gets down enough to be a useful appliance.
I left the APU set so it can kick in and keep my batteries up overnight if it needs to.
I'd rather burn some diesel than wake up to dead batteries. I just topped off about 100 miles ago.
Supposedly the fridge has low voltage protection but I'm not sure if that's set properly or at all.
@Electric Chicken Walmart sells a single cup kuerig for 24 bucks. I’m still using the one I used to carry before I retired.
