Day was made longer by leaking Doran valve stem sensors. One was slowly sleeping and the other gave out and took all my air away.
Fortunately I was able to limp it to an STTC to get aired back up and replace all the sensors with regular caps.
Normally I can air up my own tires. I even put the hoses in the truck (2 fifty footers so I can reach a trailer while still hooked to it). What I forgot to put in the truck is the gladhand and my air chuck.
A single 50 footer should reach the rear trailer tandems if you have coiled air lines. Or you install a quick disconnect into the primary air tank.
That's all I ever had to use and I used the trailer line.
Another decent day although my end of day was a bust. I was sent to take an empty out of a place and when I get there they take half an hour almost just to tell me it's actually loaded, but it's not sealed, and they have no idea what's up with it.
I have to remember that 30 minutes isn't very long in OTR time, if I wanted to get into that. I'd have to get a lot more patient.
Anywho I paused that load assignment and will have daytime fix it. There's no way I can explain that situation to offshore offshift.
FedEx dropped off my Indiana plate yesterday. Put that on this morning. Then ran down to the dealer for my new shocks that just came in.
I have inner shoulder cupping on a drive tire and the Internet tells me it's probably shocks, could be alignment, might be a hub.
The shocks look pretty old-ish and are the cheapest so I'm diagnosing those as most likely.
Unfortunately I wasn't able to get a maintenance history on this truck like I did the previous one, so I don't know if or when they were replaced before.
My best day so far since being back. Ran 3 loads from a warehouse 15 miles away then went to York to pick up a Starbucks. Those runs are still kind of a time sink, but the fuel mileage was still great. It's about an hour and a half to two hours per turn between yard for an empty, customer, and rail. Repeat thrice. Plus the initial time going from my house to the yard for the first one. Extra suck because the company yard is on the opposite far side of town.
Anyway, I'm at around 46 cents per mile on fuel. The old truck was closer to 65 cents per mile, and that was running slowwwwww.
I'm beating feet in this thing and it's still a sipper.
Chassis still suck though. The more I hook to the less I think my day cab actually had anything still wrong with it. Some good ones have you loving life, the especially bad one coming back from Starbucks was so far off track trying to murder me I wanted the day to just be over.
Taking off tomorrow. I burned most of my clock. Worked 6 days straight. Didn't work last Thursday so nothing is recapping for tomorrow. I'll resume on the weekend.
Looking closer, those shocks are original to the truck. The bottom bolts still had the factory paint on them.
I managed to get the offending shock replaced but the rest are rust jacked. My OCD has to take a backseat to reality. The top bolts came loose so I was able to at least check to see if they're good or not. They don't seem particularly bad, so I can get by for a while. Those tires aren't wearing poorly at all anyway.
I've finally ordered myself one of those induction heaters for rusty bolts to see if they're all they're cracked up to be. If not, I'll be either finally buying myself a torch or getting my dads help with his torches and we'll make them liquid. I really ought to have my own torches by now TBH.
In the meantime there's money to be made.
Are you saying there's a centralized database of repairs based on VIN?
There is in Paccar. I've taken the truck in and they tell me that this particular service has never been performed and it should be done. He had a list of items completed and the dealer that did them. No outside services were of record. ie: oil changes, tires, etc...
You may want to question a branded dealer.
Based on that, a dealer would be giving me a list of everything I already did to my day cab myself based on the fact that they weren't the ones that did it.
Those records are useless to any truck that was maintained outside a dealer.
This truck came from NC. My local dealer wouldn't have any records of repairs on it.
The trucks that were assigned to me came from Denton TX where they were built and then the selling dealer in Greensboro NC. I was using the dealers in Haines City FL and Ft. Pierce FL. Going to Greensboro would be like going to Harlem, Detroit or Chicago.
I asked the dealer specifically about records and they said they don't have any so it must not work the same.
I felt like it took forever parking my loaded trailer but it was only about 4 minutes looking at the dashcam.
Today I saw a guy in our yard with a bunk truck and a 53' trailer one time it into a hole. I was impressed! I gave him the thumbs up. He smiled and waved.
I was just put in a bunk sleeper for a week a few months ago, when my day cab started hiccuping and that's all they had. I loved it.
Yeah a couple places that I had to blindside took me more tries with the extra 3 feet and no cheat window.
But it was not as bad as I thought it would be.
I thought you could easily jacknife/ or otherwise hit the trailer on the tight turns but at least not in that tractor was the case.
I can't blindside to save my life, at least not a week in. I do the sleeper truck roll through the rail yard to get set up for a sight side in certain rows. It works out fine so far.
Most of the warehouses I go to are set up for longer trucks so it's not an issue out in the wild. At least not so far..
Overall I'll take the comfort and fuel mileage of a sleeper over the parking convenience of a day cab.
Not just any sleeper though. A high roof aero job.
Ohh you know it's just a matter of time.
I got lucky when I did P&D all day in the inner city. But I did have a lot of TL loads also.
Hey one more question about the rail yards. How does the BOL's work?
Is it more actual paper and signing or tablet and entering with digital signatures ?
