Today, is a complete bust. And I'm glad I live so close to the rail on days like this.
I get my ass up early after just barely clocking a 10 to get a load delivered by noon. Only to discover half of the latches are missing.
My second load, isn't even here. It's supposed to be delivered by 5pm today but is still on an inbound train, and probably won't be available until at least 10pm. So that obviously isn't happening either.20250302_072349.webp20250302_072427.webp
Since I'm off...
Doing some women's work around the house, spotted my little chain saw and thought hmmm wonder if it'll start easy.
It did, sort of. Once I put gas in it anyways.
Did a little cleanup around the yard as a break and to feel like a man.
It's just a little chain saw but it's great for small stuff like this. I'm not felling trees, I'm cleaning up what falls off.
My second load, isn't even here. It's supposed to be delivered by 5pm today but is still on an inbound train, and probably won't be available until at least 10pm. So that obviously isn't happening either.View attachment 90894View attachment 90895
Looks like someone took my use a hammer to turn pins the can is sitting on advice to heart. ;)
Got my Mack blanks this AM. When I got home I made two copies. Both worked first try.
Also, I learned why I screwed up the Escort ones. You don't go around the bend. IOW these keys drop off at the end, and you don't cut that part. I was cutting that part. And then when I flipped it over to line it up flush, it was shorter. Being shorter, the cuts were in the wrong position for the tumbler.
I found this out because the Mack keys are too small to have the end stick up all the way. So you can't cut it even if you want to.
In other news, I have the LTL out there idling. I'm trying to remember to start it and idle it at least every couple days so it doesn't freeze up or the batteries completely die off.
Plus it's fun to hear it running. It doesn't get up to temperature either so it probably needs new thermostats as well. From everything I gather, there are two in the housing since it's the low flow system.
The hoses get a little warm though so maybe it just needs a coolant temp sensor.
I'll probably try that first since it's easier labor wise.
Use an infrared thermometer on various parts of the cooling system. They're cheap enough on Amazon. They are invaluable for isolating hot and cold spots all over the engine and cooling system.
I do have one of those already. Two if you count the one I can't find. Even though it got up to temp on the gauge, I'll probably still do this just to see what's going on.
It's not dumb if it works! Tube broke and popped out the hole, sprayed about 2 gallons of coolant all over my engine bay. Shut me down on the side of 81 with barely enough room for the truck.
Got back on the road in about 30 minutes. Didn't need a tow. Held on for another 170-ish miles. Made my delivery and got home.
Called my dealer on the way to the delivery and they had both of those tubes in stock so I said hold me back one of each I'll get them tomorrow. On closer inspection it looks like the other one isn't long for this world either.
It's pretty bad but helpful when you have your VIN memorized.
Also stopped in at the 77 Truck Wash. Close to closing time, no trucks in front of me, pulled straight in.
Polar opposite of the Beacon with their hours long lines.
The truck was sticky and smelly all over from so much forceful coolant loss I figured I might as well get it cleaned off to make the repairs more tolerable. Got rid of the used coolant bottles ASAP as well. They were stinking up the cab.
Truck was getting a little dirty anyway so it's nice to have the whole thing looking decent again regardless of the mechanicals.
Probably won't stop in there again though. Wash was acceptable, not great. Pretty expensive for what you get. And the worst part is communication is so difficult. I don't care if a business is Indian owned/ran but he didn't even understand my name when I spelled it out letter by letter for the receipt.
Friendly guy, but a tedious process.
Then again, the wash was similar to what I've been getting at the Beacon lately and it was faster. So maybe I'll stop in and pay the extra just because time is my enemy.
Until I get myself a heated pressure washer and DIY.
That "fix" held pretty good. Debating whether I should run it that way tomorrow too and swing by the dealer with it to get the new parts vs run the car down to pick up the parts and fix it proper before I head out.
Not leaking is not leaking, right? 🤔
On the fence whether it might be prudent to get the big upper and lower radiator hoses while I'm already at the dealer. If not to replace now, but to have on hand.
They're silicone not traditional rubber, but everything has a lifespan.
