Put the drain pan together despite the stupid cold. Also broke a fingernail. :nails:
It's the same 17 gallon or whatever drain pan on casters and with a pull handle I bought a while ago for oil.
This time instead of installing the included crank pump that leaks badly, I bolted in a drill powered pump I bought to replace the same pump on the other pan.
If I had a girlfriend, she would look at my fingernails and skip the foreplay.
Then again, if I had a girlfriend I wouldn't be on hands and knees on the porch putting a drain pan together at 1am.
I've had 5 of them. 60's & 70's mind you, but still, I liked them. From a GTX to a few Newports and New Yorkers, they served me well. I wouldn't have one of the new ones, or really anything after 1977.
There was an old guy that passed away in the '90's, he had a I think '73 Newport.
I wanted to buy that car, but someone beat me to it. The car was mint!
Solved my key problem. Got myself an Ilco 027A duplicator. Because F driving to and standing in line at Lowe's then coming home only to find the teenager didn't cut it right.
It was listed on eBay as new old stock. If it was actually used, it was barely.
Nothing fancy, all manual, but MiUSA vs the Amazon junk for not much less.
100% success rate making ~6 spare keys. One for every vehicle or vehicle related keychain.
Kool! :thumbsup:
Rarely did I ever have a key made that worked the first time out. That would be a cool machine to have and it takes up little room.
It is definitely small. And light. According to the manual it was made with jobsite portability in mind. For me that means it doesn't need a dedicated space like these 35lb fancy new units.
I have Ilco blanks ordered for the LTL and wagon, and am looking for faster delivery on Mack blanks than what I've found so far, without paying stupid for them.
I'm also thinking about going to the dealer for an OEM plastic covered Mack blank once my success rate is confirmed and I know I'll definitely get it right. I have Mack logo metal ones and never had the dealer style plastic for this truck. I don't really need one, I just think it would be nice.
Well I finally got the thermostat in a little bit ago. But my cheap drill powered pump isn't adequate to move the coolant from the drain pan to the jugs, let alone up and into the reservoir directly.
So I'm going through the long drawn out process of sucking it up from the pan into the 1.5 gallon extractor and then pouring it back into the truck.
So yeah I did buy that extractor for a reason. This isn't what I had in mind though.
Also, no idea if the thermostat is properly sealed. I cleaned the mating surfaces as best as I could but they still seemed sketchy.
Fingers crossed on that.
It's 42° and not really getting above 165 just sitting here, but the other day when parked it it barely got above 100 and kept dropping.
I don't see any leaks from the thermostat housing, but I don't think the thermostat has opened yet to allow full flow either.
I think I'm back in business though. It was actively leaking when I had the truck off and the housing bolts just barely cracked open with the old thermostat installed.
