Feel like I've moved up in the world. The only vehicle that wouldn't start today is the wagon that's been parked since I got the Honda. I never disconnected the battery because I figured it would have been scrapped by now.
Anyway, I dicked around with it a little bit and got it to start with my little pocket sized Amazon booster pack that I originally bought for the lawn mower.
Battery shop I bought it (and the Mack batts) from said bring it by and they'll run it through the ringer and if it still won't charge it'll be less than $40 to replace since there's some warranty left.
So I'm going to do that. Probably tomorrow. It's windy AF today.
Why am I doing this? I dunno. It's hard to let go of that car since I have so much money and scraped knuckles in it. I also spent a lot of late nights working on that car and learning about vehicles in general. I've had the engine and transmission out of it and everything.
I worked on it by myself in a rented garage over the course of a year or so, OCDing my way through it when money came in slower than a car payment.
It built up my confidence to work on the F250, Ford LTL, and Mack.
Finally got the wagon boosted/charged enough to where it finally starts on its own. At least for now. Not sure if it still will tomorrow but it looks like the battery isn't complete trash.
I charged up the "lawn mower" booster in the house while the wagon idled so that I can take it for a spin tomorrow and get home if it dies again.
This poor little car doesn't deserve a squishy death. I'm sorry but I just can't do it.
Doing another parked forced laptop regen because I'm bored. Soot level was 29% before I started the one back on Nov 15th. It's Dec 5th and started out at 36%.
Neither one of those numbers are anywhere near close to DPF cleaning or replacement but I'm curious if I'm trending poorly. Because I don't know what the level was immediately after doing the regen last month. For whatever reason it doesn't tell you the afterwards results. Probably because it's a ghetto 2014.
Okay so there are two regen options in the Mack software. One is soot and the other is crystal sublimation (cooling off the hardened DEF).
I always assumed based on the estimated times in the software that the crystal sub option was a twofer being significantly longer in duration than just the soot.
Anyway, I just did a soot only and it showed 36%. Then I started to do a crystal sub and it showed the soot level at 5%.
That doesn't tell me whether the crystal sub is a twofer but it schooled me on how to check the soot level afterwards.
Wagon started again on its own this cold ass morning. I put insurance back on it for a whopping $30 a year before I took it for a spin.
I was simultaneously reminded why I parked it and why I want to keep it. šŸ˜€
Earlier today replaced the license plate bulbs on the wagon. One was burned out, other was same age so did both while I had the screwdriver out. Renewed registration earlier and tucked that new card in the car, and checked to see if it would start. It did.
Don't seem to need a new battery after all.
Ordered some fuel compatible UV dye and a UV flashlight to throw in the tank and see where this fuel leak is. Put the fuel pump access cover and rear seat cushion back in place in the meantime. That does need fixed if I'm going to run it for real again.
The Escort was just about the hottest selling car that Ford had. They took some real heat for stopping production of it.
Mind blowingly it even has independent rear suspension. For all its faults, it absorbs road imperfections very well. My Honda doesn't even have that and you can tell.
Truck did that sucking air thing with the transmission again. Except this time I was fully stranded at the corner of my street and rt11. Had to put the triangles out.
Usually when it happens it at least manages to stop in neutral so I can let it build air again but this time it dumped stuck in 6th and then stalled at the stop.
I know the process by now. Get the transmission air tank filled and eventually it'll all release, get back to neutral, and then you can move on with life.
My little air compressor just didn't have enough throughput to overcome the active air loss.
Started to walk back to my house and a neighbor gave me a lift.
I grabbed my car and went to the local farm store (Mennonite run, sells Milwaukee tools) and got a 2 gallon M18 air compressor that pushes 130psi. They were including 8ah Forge batteries with purchase so naturally I accepted that too.
Got back to the truck and sure enough, the bigger compressor filled the tank and let me keep filling the tank as the truck tried to shift and lost air doing it, eventually giving it enough to move back into neutral.
I threw the new compressor in the truck, drove the truck home, then walked back and got my car.
Same neighbor offered me a ride again when he saw me walking back to the car but I thanked him and said I need the exercise.
I was less concerned once I had them both off the road and in the old fire station parking lot.
Anyway, I can't exactly put this truck down for an issue that only happens occasionally in the cold, so I'm going to keep the compressor in the truck with me so I can do this process anytime I need to.
Once it's warmed up and has shifted a few times it's fine. It was butter smooth on the way home.
Just for the tow company to answer the phone is $1000.
Good on getting it back to the pad.
Exactly. $375 even without the bonus battery was a sale for me. I knew what I needed I just didn't own it. (In this instance, not just sitting on my couch online shopping, I would have actually paid double or triple).
My little cordless bicycle pump can suffice when it's not stuck in a gear. It has before. I needed brute force this time.
Extra bonus is that now I have portable air for chassis tires. And the battery makes the impact wrenches more powerful according to Torque Test Channel.
