Those are the videos I'm watching. I have no desire to experience it intentionally.
When I was a trainer I was passing through the Erie area. I decided we should opt to take the first southbound interstate to escape the lake effect snow.
The truck was heating up, so we stopped at the first rest stop. The truck grill was completely clogged with snow, so there was no airflow. We got out and scaped the snow from the grill and carried on. The lake effect gets that bad that it will clog up the grill.
I feel bad for anyone running super singles there, they suck in the snow.
In Michigan they get lake effect, and I would hear drivers talking about shutting down for the night. It may or may not get better in the morning but if you keep on going you will escape the lake effect in like 20-30 miles.
Watching lake effect snow videos on YouTube under the comfort of my electric blanket.
Has me looking up snow tires for the Honda on Tirerack.com.
šŸ˜‚
That is one aggravation I'm glad i don't have to put up with. Changing tires back and forth every year.
You can experience it in person without even leaving your state. Erie, PA has some wicked lake effect.
And to think, I almost moved up there. I went up to open a new fuel terminal near Pittsburgh. The roads about tore my poor old pick up to pieces. I thought what winter would be like and said, 'Nah, I'll stay in the south'.
Western and Northwestern PA holds no appeal to me. And I probably wouldn't move here on purpose if I was from somewhere else. But born and raised here, this is home. For better and for worse.
Where I am now doesn't really appeal to me, but it's where I am now so I deal with it. To see and do anything civilized, I have to drive either to Daytona or Orlando. Unless you are into redneck stuff, mud bogging, 4 wheeling, hunting, etc... I only moved here for the money and to return to the hell that was Ft. Lauderdale would cost me everything I have. That will always be 'home' to me. This is just a place in which I reside.
My cost of living is about half of what it was down there and still is comparatively less expensive. It was very expensive to own real property there both in insurance and taxes. I pay less than half of the costs of Ft. Lauderdale, have a 1500 sq ft bigger house and even auto insurance is less than half. There's just not much to do that you don't have to drive an hour or so to get there.
Getting preventative. New hose/glad hand/handle package. 26°F during the work, but it's better than during a snowstorm in a desperate emergency.
Also buying online is 50% cheaper than getting caught out running to the local T/A. Ask me how I know. šŸ˜
Yeah I'm in one of those areas where there's a lot of freight if you have the connections, plenty to do if you're interested, and a relatively low mortgage but would be squeezed if I had to buy all over again today.
According to everyone, my property is worth $100,000 more than I currently owe on it so they didn't hesitate to spike my insurance and taxes. But my mortgage is less than if find rent anywhere let alone another property to buy.
Kind of one of those deals where I'm better off than many but worse than I was.
We have a deal in Florida where it's called the Homestead Act. The city/county can't raise your property taxes any more than 3% per year no matter how much the value goes up or down. It also can't go down more than 3%, but when do any taxes go down. I just paid the taxes and it was $1480, only because I've owned a home in Florida for just under 40 years. When I left there, taxes were near $2000.
IF say, you were to move down here, buy my house for example, then your real estate taxes would be close to $10,000 as a new resident. If this same house were in Ft. Lauderdale, you would pay close to $20,000, depending on whether you lived near high end real estate. But, because my property down there had a higher value, I was able to transfer that tax millage rate here when I bought a property of lower fiscal value, simply because of where it's located and in an unincorporated area of the county and not a city. It can get confusing
Plugged the cooler in yesterday, let the truck get up to temp, then shut it off. Probably been at least 12 hours shut off.
Wanted to see if the new batteries would let me get away with forgetting to unplug it.
They did. It started up showing 11.8 volts.
It was also below freezing again. 26° according to my weather app.
šŸ‘šŸ‘
I'm pickled tink about that.
I think I may have solved but not yet fixed the bad def issue. I noticed when I filled up there was crystalization around the fill tube which means the joints between the inner neck and outer neck are failing.
I'm going to ghetto it up with some RTV smeared around the external neck where it snapps together.
I had already bought a new cap a while back since the original was cracked so I doubt I need to also do that.
If that was letting water in, that would affect the def quality, and make the truck freak out.
šŸ‘šŸ‘
A place I worked at tried to give me shit for that.
Dispatch says, you left your cooler plugged in.
Me, I always leave it plugged in if I go home for the night. I unplug it when I go home for a weekend. Never had a problem.
Dispatch, oh.
All because there was this rat bastard that used my truck to move a trailer.
Dispatch, oh.
Yeah I don't think leaving it plugged in for a single overnight and expecting the truck to start the next day is unreasonable for normal battery performance.
I'm pretty sure I USED to be able to do it on purpose every day I knew I'd be working in 12 hours again. Although I may be gaslighting myself.
It's not unreasonable when we consider the 10hr break on the road. Pretty sure no one unplugs their cooler when they go to sleep in the bunk and using their Wabastard heater.
I was just dealing with dispatchers that never seen the inside of a truck and no idea of how it works.
Here's what I hope to be a good enough fix for the def tank. I smeared black RTV around all the seams where it clicks together. Not sure if I got the bottom most lip enough but it was hard to get in there without disturbing what I had already done, so if it's not good enough I'll add more later and see what happens.
I'm not buying a tank and going through that whole replacement process if I don't absolutely have to. Not this winter anyway.
Fun morning. First load was set down on the lock pin. No one around to do a lift to fix it. So no go. Call rail office to report it, they say they'll fix it this afternoon. Okay fine
Move on to second load. System glitches. Can't outgate. Call rail no answer. Texts me saying she'll call me back.
Better part of an hour later calls me back. "There's been an accident on the tracks so I don't know when I can get back up there to help. I'm basically the police right now with names and interviews." Any idea when you'll be back up? "No."
Okay. Change my outgate to a bobtail and scan at the kiosk. Wait wait wait while several loads in the lane next to me get out.
Back up out of the lane and exit the in gate side. Outgate lanes have those lift gates. Ingate side does not.
Get almost home. Rail calls me.
I didn't answer. Park on the slab at home, I'm done.
It's local work, time is our money. I have zero patience.
No money today, but I wasted enough time as it was.
When that happened, we would get a big hammer and whack the handle (rear pins) until it turned or whack the pin (front pins), and the can dropped, or the handle broke whatever came first.
I don't blame you. Once I was in go-home mode that was it, I was going home.
It was a front pin and I whacked it until it wouldn't move anymore. I guess the weight was too much or it had a burr or something.
Could also be my BFH was neither B nor F enough.
I used to carry a small 5lb sledge just to get some of them to even break free. The BFH was also good for rusted, frozen slacks. That salt water ruins everything. The Ro-Ro's being the worst.
