So I read that lithium greases are compatible with rubber bushings. This thing is more of a bump stop than a bushing in that it keeps the trailing arm from smacking against the bracket, but it's not a bump stop in the sense that the trailing arm is against the bushing at rest.
Probably doesn't make sense because it's a weird ass design that doesn't make sense.
Sad on the income today just bobtailing down and pulling an empty back but I got 7.4 on the after-fuel leg which was all but ~12 miles with the loaded trailer.
9 and change on the whole day but it was tainted by that much bobtail.
Ran 62mph again when loaded since it wasn't much of a day. Boogied down bobtail since it doesn't affect me as much.
Bunch and I mean BUNCH of WV DOT had trucks pulled over today. One on my side had just let a customer go but fortunately didn't want me. I've never seen so many, not even regular cops.
Turns out, according to the group chat, that the donuts were actually supplied by a fellow driver. The company didn't even extend the effort.
Thank you, driver, even though I didn't partake but fuck you even more to the company. Because you dragged us there and did NOTHING.
Had a nice long conversation with dispatch. We got some inland port loads that pay nice and it's an account that's growing. It's those short heavy sea cans but they don't go very far so you don't use much fuel or tire. It's 16 miles round trip.
We're also seeing growth generally and she finally said she could give me enough work to justify a sleeper.
Before it was ehhhh hold off. She's a pretty honest person when it comes down to it and wouldn't tell you to go buy a truck you can't afford.
Also, a third of our local fleet is currently down for repairs so I'm all vulture-y.
Found the turbo inlet elbow online. It's pretty common, just expensive. Getting the part number and punching it into Google netted a ton of results.
So with that ordered, and the hose already here, I'm going to go ahead and at least fix that leak. That would be a pretty significant one since it's going to be pushing oil to cool the turbo anytime the truck is given throttle.
That and the rear main could actually be the biggest leaks, now that I'm really thinking about it.
The front cover is probably the next worse at least in appearance.
The oil cooler/filter housing has oil on it, but being directly below the turbo it could just be getting dripped on and not leaking itself.
If it is leaking, I'll probably have to pull it off the truck and get it on the bench to see what I really have. The parts schematic is terrifying. Hopefully it's fine. Only way to tell is take it one step at a time and get the turbo buttoned up and watch the cooler.
Just discovered there's a forklift shop/dealer right up the road from me that makes Parker hoses. Probably going to be a go-to for some of these ones with fittings. Less than 3 miles away. Can't beat it.
Used to be a chassis cab custom body shop in there until they outgrew it and moved south.
My janky fuel tank with the weird plate and bungs is leaking at the cork gasket. So I ordered some cork to make a new gasket.
It's not catastrophic but I'm cheap and don't like to see leaks. I also stuff the shit out of my tanks when I'm in Virginia getting cheap pure diesel.
Mechanic knows they don't have to be absolutely tight right?
It is possible for them to be tight and facing the right way too.
Well it wasn't tight but it wasn't tight enough in the correct orientation.
It was too windy to put thread tape on it. I tried. It needs the nut loosened up and rotated so it's snug in the correct orientation.
This was supposed to be my load out today. Trailer ABS fault on the dash as soon as I connected...but instead of fixing the ABS someone decided to just knock out the light.
The way they scrutinize our trucks, I moved on to the next load and kicked it back to them and made it their problem to get fixed.
This is one of those leftover janky POSs that they need to get rid of. Last time I pulled one a hub blew out on me along I-78.
So fuck this shit.
