Probably done with the DC/Beltway area loads for a while. Got a later start than I wanted to and got extremely fucked on the leg back. 109 miles in 3 hours, with the brief open moments being hammer down.
That's an average of 36 miles per hour. Tedious as hell and stressful with all the cutter offers.
Maybe my brain will chill and I'll settle down after the weekend but as soon as I saw the same thing for Sunday I kicked it back.
Ironically I was fine for 495/270 since it's always a shit show, but I70 was crawling from Frederick all the way to Hagerstown and that was infuriating. I was yelling at my windshield. 😀
Tomorrow we have a mandatory Hazmat meeting that's not DOT required but the company is forcing everyone even though we don't even pull hazmat and the meeting is unpaid. No one has the balls to stand up against it for real beyond bitching and complaining.
Last one was back when I first signed on here and I said the same shit about it not being required and not applicable to non-hazmat blah blah blah. But this time around they're acting like the resistance was their own idea.
So my dad's jabber jawness on Saturday at a tractor pull resulted in striking up a chance conversation with an A. Duie Pyle broker who grabbed his phone and texted me her email address while they waited in line for soft pretzels.
Finally tore the dash apart and fixed the door lock/power window issue.
Found a post online that said they share common ground and their fleet fix is to patch that ground directly to the bus bar near the fuse box.
Did that and boom fixed right up.
My Dad was like that. He couldn't walk past someone without saying something.
He ended up talking to a guy that was a senior driver at a company I wanted to get into. With his influence I got the job.
It turned out that I didn't like the company and ended up staying just long enough so he got his driver referral bonus. Plus, I bought a case of beer.
The Ford was designed and built by American men.
The Mack was designed by Al Gore and built by young hooligans who think "bruh" is a word.
The Mack was built by Marylanders and Pennsylvanias. The same ones who have been building them all along.
It's really only the hood that looks kind of stupid. I don't know who designed that.
The CHU is the "hood" version and it's the same exact truck except the hood and the axle forward. And I think it's a decent looking truck.
Looks like a compromise. We want a hood, but we still want to be able to see the FIAT 500 in front of the truck.
The CHU looks much better. It has sharper points leading into the headlight buckets. The CH version is more rounded and therefore more 'Duh' looking. It also looks to sit higher than the CHU. I still like the looks of the Ford better, but that's me.
I part-timed for a guy with a Louisville 9000. That truck would beat the snot out of you.
On the plus side, when the cab is directly mounted on blocks it doesn't rock and roll as much. 😂
Fortunately mine has air ride in the seat and rear suspension so that helps.
Sitting in Upper Marlboro for my pickup. Had a 2 day window for both the delivery and the PU so I thought hey let's do it at night because no traffic.
Joke's on me because no one informed me that they aren't open until 6am on Tuesday. I was told they were 24/7 except the weekends. I guess Monday is part of the weekend. 😏
Now waiting on our night shift to okay me bringing the empty back. I don't mind waiting since I need a 30.
I can't wait 3 and a half hours for them to open. That whole ELD day cab thing.
Parking the truck back where I showed that photo is kind of a thing now. And now that I actually go to the back of my property daily I see the Ford and want to restore it and try to use it.
The biggest thing really is the oil leaks. It doesn't burn it but it has so many seals shot that I was putting in a couple gallons every day. I can't afford that.
It needs a taller transmission.
But otherwise most everything else is about making it pretty, not functional.
A couple of gallons a day?? Is it an 8V-71/92 Detroit? That's a lot of oil. Seals as in crank, air compressor, etc...? Or simple R&R gaskets? Side covers and rocker covers. Wash it down and then run it. Repair as needed. It'll keep you busy and away from the TV.
What would be cheaper, a taller transmission or a tall cog rear chunk?
It's leaking everywhere. I didn't just wash it down, I bought OEM Cummins paint and spray painted the engine after doing so. Not to hide anything but to make it more visible.
Nothing is unfixable but it's not a high priority at the moment.
A taller transmission would be better if not cheaper since the original 9 speed is worn out and the rear main is one of the leaks to fix anyway. Plus it's not exactly a HP monster so the lower rear gearing helps.
So, it's probably a Nifty 350, Big Cam III or IV.
That truck would fetch $30k down here and wouldn't last but a day or two in a high traffic area.
It's a BC4. The cam covers are also leaking. A couple of them anyway. Minor though compared to other things.
Front cover is another leak. Turbo inlet too. Got a hose on order now actually but not sure if it's that or the adapter itself. Will order that when I find one. It's all old so when I do replace stuff I'm replacing for appearance too not just function.
Lots of hoses to replace for appearance. Basically all of them. I did new power steering ones not that long ago. One for function, the other for appearance. Need to R&R the reservoir and bracket for that particular thing to look good. Or just buy a replacement.
I mean I'll probably start doing more as the Mack tapers off on the attention aka money it needs. But I can't just go full tilt on this thing all at once.
I'd probably have more done if it was under roof though. Or so I tell myself.
Lots of little things need done and some of the leaks have bolt ons blocking their access.
I want to redo all the plastic air lines and such. Just tidy it all up.
This would be for me at this point, not necessarily to sell it. Not going to do all this only to have it go south of the border and get killed.
Oh side note, I was able to simply pry the trailing arms on the Mack and get some lube between the arm and the bushing. And it is a rubber bushing. A really hard one.
It was a random thought I had to try so I just shot more silicone spray in there instead of grease. The spray and pry bar were right there in my truck and the grease gun was all the way up at the house. 😂
We'll see how much it helps if at all. I'm learning about these things little by little.
