Made a handling discovery about some of these chassis. Maybe I discovered it and mentioned it before but I definitely forgot if I did.
Some of them don't have flat kingpin plates. The brand new Hyundai ones have a flat plate that sits completely on the 5th wheel.
Some (maybe all) of the older ones must have a bow in them that when sitting level allows some space on the outer perimeter of the 5th wheel. That means it's more prone to rocking and less stable. I don't know if it's deliberate to have minimal contact and therefore easier turning or if it's age/defect/poor manufacturing.
I can't do anything about it, but I can keep it in mind when wondering why shit rides like shit.
and yes you can delete all of the nanny bullshit that will have you ripping your hair out at the end of the day. though my dealer said it would need to be special ordered since what ever he had on the lot had all that crap in it
Up at 2 today, no alarm. Way too early for my appointment loads. So I went back to sleep. Got up again at about 5:30 and ran both loads in. Had to bobtail out.
Truck threatened a parked Regen so I couldn't do my last load. If I got stuck doing an hour plus Regen somewhere along the way I'd run out of hours. I was down to almost nothing on my 70 so I didn't have a lot to work with in the first place.
Third load was an all day window so they shouldn't have trouble repowering it.
I did it that way on purpose, taking care of the tight window stuff first because that would require a complete reschedule and probably late penalties.
Was dropping one of the trailers off today and shut the truck down to go inside to the bathroom. When I came back out and proceeded to formally drop the trailer, I noticed a pretty obvious creaking sound coming from the trailing arms. I probably wouldn't have heard it if the yard wasn't dead silent. I mean just the sound of clicking the glad hands into the holder on the truck was loud because there was NOTHING. No other trucks moving or idling, no forklifts banging trailers, NADA.
Anyway I don't know if you can tell but in the upper part of the trailing arm there's a gap (not the huge gap but up near the crown). Before I sprayed it (shoulda taken a pic) it looked like the two pieces rub together on a regular basis. My logic is that if they're supposed to rub together, and they're creaking, they're probably not lubricated, and that could contribute to handling issues.
I have no idea if there's enough gap to get the silicone spray in there but I gave it a shot.
Looks like it might be a bushing up in there. Kinda feels like it. Not sure if my silicone spray will help or hurt but I made sure to use explicitly bushing safe stuff just in case. Not that I have any idea if there's such a thing as bushing harmful silicone spray.
Why won't the truck regen under operation on the road? That doesn't make sense to demand a parked regen. It's not like you sit and idle for hours sleeping...or do you? :stirpot2:
It gave me a bad def message so probably that. Usually it's a passive thing.
I've only ever done 2 parked regens (aka in the wild) in the 3 years I've had it and the message was the same. Bad def.
I think I've done 3 now at the house.
FYI there are actually 3 types of regen. Passive, Active, and Parked.
Passive is just hot exhaust while you drive. Active is hot exhaust and the 7th injector dosing the DPF with diesel while you drive, and parked is the deal where it won't let you run and tries to burn down the whole neighborhood.
Probably also doesn't help that I'm not often under full load as in 80k gross. I'm actually never working it that hard because our heaviest was the paper loads that usually had me around 70k. I think sometimes they'd get me to 72 or 74.
My heaviest these days have been 38k out of Upper Marlboro and that makes me 69k.
I always knew when the X-15 was regenning. Oil temp increase, pyrometer increase, torque usage increase, lack of power and delayed throttle response.
***Hey, I'm doing pretty good here!
I'm up at 03:30 every morning. The wife says I'm nutz, especially when I don't have to be. I love the early morning. I get more done before 09:00 than most people get done all day.
I'm starting to actually like it. My only dark driving is the first little bit and it's when I'm fresh not when I've already driven all day.
I'm not putting in extra long days I'm just driving a little faster to consistently get more than just that one run. Been working 9-11 hours.
