I remember things at random. Noticed the rail repair shop took delivery of a brand new Lincoln welder complete with shopping cart today.
Whether that will improve my quality of life is yet to be seen. It was a pretty welder though.
Forgot to set my Sunday alarm but got up at 3:39 without it. Got rolling from the rail just before 6 after some nonsense issues outgating.
Partly CSX fault and partly mine for not noticing it. They put it on an XPOZ chassis but put it in the computer as an STGZ. That information is auto populated in their Xgate app and I didn't catch it and change it. So basically it made me sit there 15 minutes before failing and erroring and finally letting me go in the office and get it fixed manually.
Now that I'm home I can finally say it.
Took me 9hrs 55mins. Approximately 20 minutes of delays on 270 coming back, otherwise it was just some issues at the customers adding a couple minutes each (probably 20 altogether) so basically 40 minutes of delays in all, which really isn't that bad since the customer delays were on duty time not driving.
81 down, 66 across, and all of 495 was fine. Most of 70 was fine.
I fully expect tomorrow to be the real shit show. 😬
2pm home and off duty. Wasn't a flawless day but could have been much worse.
I'm doing another one of these tomorrow and still not going anywhere near Upper Marlboro. Have an around the corner delivery instead. I'm deliberately avoiding the DC area because there will most likely still be holiday travelers making it extra suck.
I think I got lucky Sunday and that's as much fate as I want to tempt.
Side note, 1200 RPM (68mph) is pretty smooth compared to 1125 RPM (62mph).
Pushing the air at 68 is worse for fuel economy, but a lot better for DEF burn.
It's a lot less shakey for comfort. Cyclical shake at 62 is pretty bad. Haven't figured out what's going on 3 years later.
So basically spend more on fuel, less on DEF, keep the EGR clean, get more shit done, and maybe profit more. Tire wear is up and all that but it's hard to quantify.
Does anyone know what would make a truck shake when it's slowing down or when there's downward force on it?
Jake on max and 1400 RPM and up it's violent. Really bad. Feels like it's going to come apart.
No Jake it's less but still there. Medium Jake same as no Jake.
Neutral rolling downhill same as medium/no Jake.
Feels like it's in the butt not the steering wheel.
It's also "coarse" when pulling low. Like getting up a hill.
Is my clutch dying?
Clutch doesn't slip in the traditional sense of high RPM with little to no movement.
Transmission itself is a Mack factory reman of unknown mileage. Most likely rebuilt in Harrisburg PA.
Is my clutch dying?
U joint?
I was going to say U-Joint also. If not, look at the carrier bearing and/or slip yoke, then the forward pinion lash. They way you are describing it though, it points to the driveshaft.
Do you mean driveshaft imbalance?
I don't know what pinion lash is so I'll have to dig into that. There's no carrier bearing on this truck, they just used one long driveshaft.
I'm not sure I understand this. I've always been taught and shown to lay under and try to turn the driveshaft as it sits. Too much rotation, replace things.
Pinion lash is the load placed on the pinion gear meshing into the ring gear. It requires the right tools to set the lash correctly or you can toast both pinion and ring gears. Generally, once set at the factory, it's good for life unless you're pushing the million mile and beyond mark. You're just half that, so no major concerns.
To check the u-joints, it's both an up and down movement and rotational. Both can easily be seen while moving the shaft. To use one long shaft, the W/B must be about 200-220 inches. Movement of one section of shaft at the joint may indicate wear of the joint. Ride height plays a major part in drive line issues. When unladen there is a measurement, usually on the frame near the ride height valve stating the measurements from set points on the frame rails and/or axles.
I don't have a truck here to get a picture of it anymore. But standing ride height would be the very first thing I'd check. A simple adjustment is free and could save you $$$ in parts changed for nothing. If you're unsure, which I doubt, have the dealer check and adjust it.
I'm at the same right height as I was when I had it at the chassis shop several months ago and they said all was good but put that wedge in my steer axle to level it out and adjust caster. That fixed the incessant pull I had and made it track dead straight.
My big nasty vibration is when I turn the Jakes on max so I'm not really thinking driveshaft or u joints. Those u joints were put in shortly before I bought the truck.
I found a Mack forum and there's a thread talking about the Jake brake pistons becoming tight on these engines and those symptoms sound a lot like what I have going on.
There are times when the truck under normal operation couldn't be any smoother.
When I say it shakes with the jakes, I mean it feels like the truck is coming apart. It's not just oh it's beating me up under there.
