Thanks. I'll get 'er one way or another. My dad has a 220 amp compressor I could run up and use if my truck can't push enough air.
I did upgrade the hose to a longer 1/2" ID and appropriate fittings. It was on my cheapo harbor freight compressor in the trailer.
My air gun has the 1/2" chuck but at only 1100 ft lbs doesn't kick enough on a rusty 1 7/8" nut even with PB Blaster working on it.
The 1" says it's rated to 2000 ft-lbs. If that don't work...$3700 it is.
The press they spec for this suspension is only $800 so I might even just get that and do it all myself.
It's a simple design, it's just a matter of getting it up off the ground safely and the big fasteners off. The rearmost ones can be done with the truck sitting on the ground.
