Okay so apparently this pump doesn't have enough power to lift. It is indeed gravity fed. Or at least it doesn't have enough power to prime itself.
I technically don't have a reservoir. I used that term loosely. I'm drawing it directly from a hole in the bottle with a hose fed to the bottom.
If I reposition the bottle up high, it can gravity prime and keep going.
I made a bracket out of spare sheet metal to hold the bottle where the OEM reservoir would have been.
I don't feel like spending $100+ on a used Ford reservoir.
If I can't get the bottle idea to work, I guess I'll buy an aftermarket tank.
do you have a local junkyard nearby? go and see if they will let you look through the junk cars for a good washer bottle and pump that would work for you.
I thought about that. Or my old Escort sitting in weeds at my Dad's. There are a bunch of plain square ones though online that can bolt directly to the firewall or be mounted on a much simpler bracket.
On the plus side, it's no emergency. I ran 75 miles with it hanging and it never stopped working.
