New lock cylinder fixed the old truck right up. Casual key on, everything comes to life. Fire up the truck, let go of the key, everything stays on. 👍
I got an NOS one from eBay because my OCD can't handle a "Made For Ford" key. I need an actual "Family of Fine Cars" one to keep my eye from twitching. Even moreso since the door locks and key are OEM.
I hear ya. I like OEM parts over any kind of aftermarket myself.
The shop where I got my Mack uses OEM key blanks so they gave me 3 of those with my truck. I appreciated it a lot compared to those weird generic ones USX and Schneider used. I mean they're all the same shape and were for FL, Pete, Prostar. I probably have 50 of them laying around and have zero clue what each one fits. Once the cheap plastic tag with the unit number disappears you're screwed.
I gave a guy who had it parked under his tree $300 for it back in 2014-ish when I was working for Amazon and didn't really have two pennies to rub together or credit to buy anything for real money.
Rented a 2 car garage for $100 a month and used a donor car with a bad subframe to piece this one back together and pulled the motor & trans to replace seals and the torque converter. Replaced the water pump and timing belt, put new axles, coilovers, springs, shocks, tie rods, ball joints, etc in it.
Basically got it handling and driving like it was new, except it's still ugly. Paint is mostly gone and one door is spray bombed green because it was from the teal donor car, as the original was sideswiped. Somehow it barely got the driver door, hit the shit out of the passenger door, and didn't touch the rest of the car.
It had 192k on it when I got it and it has 216k now. So even over 9 years neither my dad nor I put many miles on it.
After getting it back from my dad last year or so I had to put two new tires on the front and replace the radiator but I think that's it. I put LED headlight bulbs in it (the same kind as the Mack, not ones that glare) but that wasn't really a need.
So yeah it's been a cheap car to operate over the years.
Out of morbid curiosity even if I get a newer car, I plan to run this one until something major goes wrong. I want to see just how long it'll last.
Some of these cars on the dedicated forum I used to visit had over 400,000 miles. Seems like they either blew a valve stem early ie under 150k or they ran forever.
Oh I just remembered I also put a new EGR valve on it and cleaned out the lines that run to and from the DPFE sensor sometime since getting it back. The valve was like 20 bucks.
They get carboned up over time and make the car run like crap and use excessive fuel.
Cab shocks are off. I was previously under the impression that the bracket had to be removed to get to the upper nut since it's inside the bracket and inaccessible with a wrench. Turns out it's captive ie welded in place. Bottoms are easy being a fully exposed through bolt.
Anyway I had procrastinated due to the assumed PITA factor. Tomorrow I'll go down to the dealer and buy new ones and slap them in.
I pulled on the old ones and without the new ones to compare can't really be sure it'll make much difference, but they're over 4 years old. Maybe it'll be a subtle change that makes a bigger difference on the road. Or it'll just be a small difference only my picky ass will notice. Or it won't change a thing but I'm replacing them while I'm in the mood to do the work.
What I do know is they aren't completely shot. I just don't know how far along they are.
Not even that. I was just cruising in the slow lane at 68 with nothing around me. He jumped around at some point and cut me off for no reason. I wasn't trying to get by or do anything.
Oh wait I see what you mean by "get by"...yeah he seemed to think his 69.2mph was going to last all the way up the hill I guess.
I throttled up and hit 75 in a second then jumped over in front of him. I didn't brake check him but I gave him as much space as he gave me. I hope he had automatic braking and I hope it activated like hell.
He either wanted to hit the bottom of the hill at his top governed speed & you were in his way, or he didn't know there was going to be a hill.
7:10 called Mack about shocks.
7:41 left house.
8:44 arrived home.
9:05 put tools away.
New shocks are definitely firmer than the old ones. The old ones weren't completely dead but I'm confident it's going to make a difference.
I looked into finally replacing my transmission air tank when I was at the dealer. The only supposed direct fit was this big ass long aluminum thing that obviously wouldn't fit. Mine is a short fat steel thing under the cab.
I'd have paid the premium for an aluminum upgrade of I could remove the old one and bolt in the new one, connect my two lines and be done. But I'm not paying the premium AND having to rig up an entirely new mounting and connection system.
So that project is still on hold. Hopefully it lasts long enough to do it when I want to, and not when I have to.
Isn't OEM available? Maybe at least order it and get it whenever it comes in.
They thought the aluminum was OEM. The steel one they had listed was identical except steel.
They have varying configurations for the transmission tank. This one happened to not be mine.
I told them to figure out which one mine takes and get back to me.
