Waiting for the grass to dry, finally working on pulling the steering column of the F250 apart. It ran out of the "push" that activated what few electronics it has...fuel level, oil pressure, radio, etc. If you hold it forward it'll still read but as soon as you let go it loses everything. Stays running though.
Turning it backwards to accessory is still solid and everything comes on..
I'm thinking it's a rod and the rear rocker pushes it but the forward no longer does.
Got the steering wheel off, pulled the cylinder. One plastic tab was broken off and as soon as I touched it the other broke. It was for the key in ignition buzzer circuit but it may control other things. The tabs were responsible for keeping it in place. Without them it had play and was moving around.
I don't know if that's related to my key on no electricals but I did fiddle with it enough to get temporary function while waiting for the NOS cylinder to arrive.
Even if that doesn't fix it, it was obviously broken and needs replaced before it's worth the trouble of continuing. There is a lot of play in the cylinder itself. I don't know if that's affecting the interaction with the rod or if the rod connector has its own wear.
I'll find out when I put the new cylinder in. I'm not removing all that grease for no reason.
Everything is back together for now.
Anyway back to me.
Finally replaced the mower blades. Got the front and about 40% of the back done before it bogged down due to being wet.
I don't usually mow wet grass, but I couldn't go through the hassle of boosting the mower, firing up the generator and compressor, pulling out the engine hoist and strap, changing the blades, and putting all that shit away again and not try it out immediately.
Do you lift the mower to blow all the grass off the bottom of the deck at the end of the season?
So does my cub cadet, and my Honda push mower.
I didn't try the one on the Cub but on the push mower it's a pathetic joke.
Does the mower have to be running when you do that, so the blades blast the water around?
I dunno I didn't say I actually used it. 😃
I watched my neighbor do his once. He hooked up the hose and had the deck running full tilt. So I guess that's how it's done.
Well that makes the most sense.
Lawnmower blades are bent upwards on their trailing edges to work as a fan, sucking upwards on the grass to make it stand up, and to create the wind that blows it out the discharge chute (unless it's one of those retarded mulchers designed for retards who mow their lawns every single day...)
So injecting water above the blade should blast it back up against the bottom of the deck.
My cub cadet is the largest of the GTX models, which sucks actually. LTX means lawnmower, GTX means garden tractor, which is bigger and more expensive than the LTX... But it sucks and I'd rather have an LTX model simply because the LTX has a vertical shaft engine & the GTX has a horizontal.
The horizontal shaft engine means it has to use a mule drive to run the blades.
A mule drive is when they use pulleys to redirect the belt from a horizontal shaft pulley to the vertical axis blade shafts, and even with a brand new belt they squeal & smoke when you get into thicker grass.
Because of the mule drive on the bottom front, it's a bitch to lift the mower up with the floor jack to access the blades.
At this point I'm just rambling about irrelevant shit so imma shut up now.
It's all good. I wrapped a tree saver strap around the bagger counterweight and hooked it to the engine hoist to get my ZT off the ground.
It's easy to do, it's the digging everything out that sucks. Plus I still need a new battery but refuse to get one this close to winter. So I needed to jump start it in the trailer first before I could drive it over to the garage.
If I had a way to lift it out in the trailer it wouldn't have been worth complaint, I never would have had to start it, and I wouldn't have felt the need to test it in wet grass.
I probably still wouldn't have my grass mowed though, and I doubt I'd have tore apart my truck's steering column either. Since the mower blade replacement gave me the momentum, and I wanted to do something while the grass dried enough to finish the job.
So it's kind of all good.
My Cub Cadet is a traditional riding mower. Conventional steering. 22 hp horizontal shaft V-twin Kohler. 54" cut.
My ZTR is a Gravely, 54" cut so I think it's a tad smaller than yours. 23 hp vertical shaft V-twin Kohler.
But because the deck belt stays on a vertical axis, there's no slippage.
When my grass is tall like it's rained for a week straight & it's thick and green and needs mowed badly, I can run that ZTR at full throttle & plow through the grass at 8-9 mph. There's no speedometer but it's right about the speed of a person jogging. And it just blasts the grass out probably ten feet out the side.
The Cub Cadet on the other hand, can only shorten the grass by about an inch, at full throttle, slow forward speed, or the belt starts slipping.
I don't get it... It's like it's designed for idiots who mow their lawn every other day and maintain it like a golf course. It's definitely not for people who have better uses for their time than mowing the lawn every other day.
My ZT is a 54 with a 26(?) Kohler. It bogs down in wet grass thats too high. I was probably at about 8 inches though. I neglected it something fierce...again.
No problems once it dried out.
Anyway back to me.
You might hafta change them blades again now
I have a neighbor that mows his yard every 3 days. WTF is that about? He wears out a lawnmower faster than anyone I know, even the commercial landscapers. It also depends on the type of grass you have. I do mine once a week in the summer and it's getting to where it can go 2 weeks, then maybe once a month when it cools down. It looks awesome when cut wet. For some reason, it just does a nicer job. :dunno: I also wash the underside each time I use it, wet or dry.
I can understand the mask while mowing. He may have an allergy to certain grasses or weed flowers. Many of the commercial guys wear damp bandanas over their mouth and noses. Now in the rain, well...... stupidity there.
I used to wear ear muffs and safety glasses while weed-eating and edging. I got rid of the gas powered weed-eater and went greenie with electric edger, weed-eater, blower, hedge trimmer and pole saw. So much lighter to operate with. The battery balances out the weight and takes a lot of the effort required out of the job.
I'm just gonna get some goats.
