Disaster averted. Was taking the trash out, walked past my truck and saw this in the tread. It didn't penetrate the carcass to leak air but if I kept running on it, it eventually would have.
I found a lag bolt in my lawnmower tire once.
Pulled it out and plugged it but the hole was too big and it leaked.
So I pulled it out, put some glue on the lag bolt and put it back in.
It's been like ten years and it's still holding air.
pffftt..
if'n a racoon turd can make your tire go flat...??
buy better tires.
ppsql81caze8r2imi7kb
pffftt..
buy better tires.
What if it wasn't a racoon turd?
It could also be a Tootsie Roll.
I don't eat Tootsie Rolls I find on the ground. Just in case it's not a Tootsie Roll. You can never be too careful.
Remind me what year your Mack is?
I'm sitting here in this 2015 Mack rental with the peekaboo window on the passenger side door down by the floor with absolutely no way to put the regular window down.
Or am I missing something.
Mine is a 2014. Maybe yours has a blockage.
Does yours have the extra glass two pane glass window right beneath the main window.
Looks like thats the blockage cause as soon as you would start rolling that down it would overlap that bottom window.
I'll post what I'm talking about later.
Mine has an outter in the metalwork then an inner on a hinge in the panel.
Yeah then it's pretty much the same setup here.
I guess the window could come down between the two bottom ones
I see the place where there use to be a handle was apparently removed and covered with a plastic do-dad for some reason.
Mine just has a thumbscrew to secure it. It opens so you can clean the glass.
