Electric Chicken
Probably so named because he's a snake.Good thing Jeff Bezos didn't go with the name Amazing. Because it is not!
Jeffery went with Amazon probably because it is a jungle out there!
Just curious what you consider “lug” rpm?I didn't run my normal putzy speed though. I'm trying to work the truck a little more and lug the motor less
It turns about 1050 at 62 which is barely top gear and downshifting on the slightest grade.Just curious what you consider “lug” rpm?
This is partly why I went from 3.08 to 2.64 rear ends.I've gotten too lazy to push the button to force a downshift sooner, by the way. I've been mostly a SWH for a while now.![]()
Tires will make a huge difference too. I definitely saw a difference when I went from Xline energy D to roadmaster tires and back. Like an 0.8 -1.0 mpg difference.
Hell ya you can help me yard jockey, If you want to help, I need you to get under the trailer and mark and measure the brake stroke while I push the brake pedal.Yardies at Amazon stalking me after/during my pretrip while the trailer was still in the door being loaded.
"Can we help you?"
"Nope."
Then started following and watching me.![]()
Weren't even jockeys. Just the goobs who walk around and check trailers.Hell ya you can help me yard jockey, If you want to help, I need you to get under the trailer and mark and measure the brake stroke while I push the brake pedal.![]()
Shut the F up man. I don't want to know about this crap in advance.Volvo/Mack like to over tighten the zip ties on the wiring harness a bit more than needed. As such, the $700 harness gets damaged and can result in a diagnostic nightmare.
These shorting issues have a propensity to fry the $2900 abs module in the dash as well.
Can you take a wild guess how I know…
