Electric Chicken
What the...How does he feel about you puffing him?
Interesting autocorrect there, Android keyboard.
I'm not getting anywhere near enough loads for that to be an accurate statement. Or a worthwhile endeavor.
Basically yes. All of that.I suppose just dropping it in the street would result in not being paid for the entire trip from the beginning?
I hate talking to out of the country support. They read canned comments off of cue cards and have no brain in their heads to make any kind of decision. And for that reason, they will always remain a stupid phone person.
Update on this: I still haven't been activated to run their freight.Beautiful day for a leak test.
As I'm sitting outside the clinic in my car, Swift calls me about their fuel card. I say sure I'd like your fuel card...if you actually finally approve my application so I can run your loads. It's been months and everything is still pending.
She has a guy call me back within a minute and forward him my documents directly, which I do.
Like, seriously folks this is how easy it should have been 2-3 months ago. Not this pending garbage and no replies to emails or phone calls.
They have work around here, I just hadn't been able to pull it.
You can replace just the oring.I believe NOW I am done with Amazon. Load to Carteret, original plan was bring an empty back but halfway there they changed it to bobtail. So I didn't have to wait or anything, and being early was beneficial. Not gonna complain about that. 8.6mpg per the dash running 70 most of the time, even with the trailer. Low 7s per the dash when I got to NJ with the trailer.
Seems like I'm better off running faster so it doesn't lug the hills than I am running slow due to the lack of aero.
I also found a tiny air leak at a push fitting on my governor. I believe it's the reason that I still drop down to 50psi in 24-48 engine off hours.
When I first saw those parts numbers I thought they were for hubcaps.You can replace just the oring.
These are from Volvo part numbers.
Otherwise Iāll put compression fittings on.
I don't even know how to disassemble it to get to an o-ring. I bought a 5 pack of fittings for 11 bucks instead.You can replace just the oring.
Why would I do that when I already, as stated, have a shit pot of o rings already? An o ring with a Volvo part number assigned to it isn't anything special over an o ring without a Volvo part number assigned to it.Or you could order the oring part numbers I gave you and have them on hand..
I just had to order more
Good thing Jeff Bezos didn't go with the name Amazing. Because it is not!My thought process in booking that load was financially it's about the same as when I'd load out and bobtail back. It's just opposite.
Had they actually loaded it, that would have been the case. With it saying loading in progress with a trailer assigned to it, it never occurred to me that it would be sitting empty in the yard with the doors hanging open and end up being a cancel.
They don't usually assign a trailer number unless they're actually working on it.
