Well I have a torpedo heater that will heat it in 5 minutes but it's been abandoned in the east barn since like 2008 with kerosene in it.
I have no idea if kerosene goes bad like gasoline.
But even when the damn thing was new, it would never ignite unless I removed the top cover and held a propane torch by the spark plug when I plugged it in.
Also torpedo heaters don't burn efficiently at all until the nose cone thing is glowing orange.
So unless I wanted to gag on the unburnt kerosene fumes I had to point it out the door for a few minutes when I first turn it on.
That'll be a pain in the ass in this workshop because of the insulation. If I simply fire it up and leave it on, it'll get too hot in there after a while. Even with all the tools and high mass objects sucking heat out of the air.
get a waste oil stove wood burning stove or a pellet stove with an auger in it to feed the stove
Does Kerosene Go Bad Over Time?
yes kerosene goes bad over time
I'm definitely going to bring that house furnace in from the chicken coop and inspect it though.
Mice could be living in it, they could've chewed up the electrical wiring. The burner or heat exchanger could be rusted out. The blower motor or fan bearings could be seized. The gas regulator could be junk. Gas lines could have spider cocoons in them, etc.
Also even if everything seems OK I'm still going to run the blower fan on bypass (using jumper wires to power it with no power or gas lines connected to the rest of the unit) for a few hours just to make sure it's reliable just in case the safeties are bad.
There are safety sensors in a furnace. If there's a booster fan for the exhaust flue, there's a diaphragm suction switch that turns off the gas if that fan fails. There's also a "rollout switch". If for some reason the flames start rolling out of the combustion area, like a flue obstruction or something, the temperature outside the combustion area rises and the sensor shuts off the gas flow.
Electronic ignition systems have two thermocouples. The electronic spark doesn't light the burners, it lights the pilot. One thermocouple verifies the pilot is lit and tells the regulator its OK to send gas to the main burners. Then another thermocouple verifies the burners are lit.
I would bet money that the little aluminum tube that supplies the gas to the pilot has spider cocoons in it.
There's also a safety sensor that turns off the burner if the exhaust gas is too hot or if the temperature up above the heat exchanger gets too high.
And if it's new enough it'll probably have carbon monoxide sensors.
That's a lot of stuff to test, and diagnostics would require downloading a schematic if any of those sensors are bad, even if they're not bad but are doing their job as intended.
We have a construction company in town. Pretty large with like 25 backhoes and lots of dump trucks and other heavy equipment. They have two of the largest waste oil heaters that run 24/7/365 just burning up oil outside. They have more that are used for heat in the garage area also. On top of that they have to pay a company to take the rest away. It's against the law to give it away to like a small garage or other businesses.
Same thing with Van Wyk's shop in Iowa.
The maid sent me on an off-road ATV mission and I had an excuse to ford the creek. :)
She wanted me to go find hedge apples to put around her house to keep mice or spiders away or something.
During the great depression, drought followed by wind resulted in dust storms as topsoil was stripped away from the fields.
In response to that, farmers all over the country divided up their fields with hedge rows.
They planted rows of Osage Orange trees. No idea how they came to be called hedge trees.
A guy I worked for back in the 90's grew up in the same neighborhood I did, a generation earlier. One day we rode our motorcycles into the woods and stopped at the spot where every generation used to build forts as children and get drunk as teenagers. (except today's trash generation shoots heroin there).
There's this big Osage Orange tree there. Louis said that tree was already dead when HE was a kid in the 1970s.
About a year ago I was in the neighborhood because Mrs Duck's parents still lived there and we walked into those woods and that tree is still standing.
So it's been dead for AT LEAST 40 years and it's still standing strong.
That's good wood.
I had two walnut trees that died and in less than a year they were rotted below ground level and had to be taken down because they were a threat to the house.
Osage Orange trees are creepy looking, don't get much taller than Apple trees and are full of thorns. Their fruit are the size of softballs and are inedible green things that look like brains.
Supposedly they repel mice and stuff like moth balls though.
Bottom center of the pic.
Old lawnmower tire.
Gotta carbon up my footprint.
Just doing my part to save the Eskimos from hypothermia. :cool:
That's good wood.
so who's the maid mrs duck:confused-96:.. maybe sending you on an atv mission is a polite way of telling you to get the hell out:D
I didn't do jack squat today except halfway install a floodlight over the door.
I totally suck at bending conduit, . . I needed a simple 90° bend, with the bottom of the bend, the horizontal part, exactly 29" below the junction box.
Knowing damn well I don't know how to figure out the radius of a quarter circle of blah blah blah I simply added 8 inches figuring I'd cut off the excess with the port-a-band and leave it looking all perfect like I actually know what I'm doing with a conduit bender.
(It would've been perfect if I'd used a hydraulic bender though.)
It ended up being 6 inches too short.
So I cut that end off the stick and did it again, allowing 17" extra. . . . This is a tight radius though. If I was able to make a 360 circle it would have a diameter about a foot.
So. . . This is why I don't mess with manual conduit benders.
Anyway my 2nd attempt worked. I had to trim off 1/4".
But now I'm out of conduit.
My measurements, continuing to where I'll put the switch, then to the circuit panel, will require about a stick and a half.
So I was about to go to Menard's and get 5 sticks.
I started to leave.
With no pickup truck I can't fit ten foot sticks of conduit in my car so I'd have had to hitch up that noisy trailer or take the van because it has a luggage rack.
Then I'd have had to dig out bungee cords from my car, but it's locked up and the keys were upstairs in the house.
And Weatherbug said its 35 degrees out or something so I said screw it & decided to taunt liberals on Facebook instead . . .
Even though I highly doubt I have any liberals on my Facebook because surely the extremely inflammatory stuff I've been posting for the past year has caused them to all unfriend and block me. Nobody ever posts any dissenting comments. :toothpick:
So I'll go to Menard's tomorrow instead. :cool:
Unless I see too many hilarious political memes on Facebook. :rolleyes:
