Well it ain't lightning no more so. . .
It's gonna be a bitch to cram insulation in there.
Not sure why your not like every other home owner and lay the wire over the joists, twist the wires and black tape. You wasted all that money on pipe, clamps and boxes.
can you imagine what would happen if he hung a ceiling fan:stare1:. and more than likely it the fan would be a code violation hung like that:stare1:
Building code. I don't redneck anything intended to be permanent when it comes to electrical wiring.
Bullshit. If I installed a ceiling fan, as a new installation, you'd be able to hang a car engine from it.
and what kind of car engine can you hang from a plastic box a fart car engine:confused-96:. out here ceiling fans require a metal box under building codes..
looking good though keep up the good work:thumbsup:
Yeah the car engine was an exaggeration obviously but I'd drill four 3/8" holes in the metal box and bolt it to the center of two parallel pieces of angle iron. The ends of the angle iron would have flat plates welded across the ends forming a shape like the Roman numeral for two. Those end plates would be screwed to the joists with a minimum four #8 x 1-5/8" screws at each end.
That way the fan can get out of balance and wobble all it wants & it won't come down.
Children can do stupid things to it, a cat can attack the blades, etc.
Building codes are a minimum requirement. There's nothing that says you can't build it stronger than required.
But yeah I just realized I need to get a steel box when I get to the center row of lights. I'm only putting up one ceiling fan.
I'll post pictures of how I mount it cuz it'll be tricky being ten inches below the rafters. I might have to do some really fancy stuff.
But guaranteed it'll be strong as shit.
Keep in mind the closer the fan is to the ceiling the less effective it is. They make extension rods for that purpose. That's why in a factory or other place where it's used to bring the heat down they hang like 4'
Yeah I know. The fan I plan on using only has a 6" drop rod.
But. . . Duck can weld. :D
I only want a 2 foot drop though.
And I mean two feet from ceiling to blades. The fan itself without a drop is like 8" or something. I ain't putting up a 13' 5½" high ceiling to have a ceiling fan in the way.
I plan on eventually having a gantry crane in here and building the crowned king of pickup trucks.
I have a traditional shop crane but it's barely got the clearance to lift an engine out of a Camaro with flat tires.
I want to be able to have a Ford twin I-beam truck up on ramps and still be able to hoist an engine in & out.
Harbor Freight has a gantry crane for like . . . I don't remember, like $900? Plus you gotta buy the trolley & winch (or manual chain fall). It's only rated for 1000 lbs I think. How much does a big block gasser weigh? :dunno:
Ceiling is almost halfway done. One more row of panels and I'll be working on the ceiling fan mount.
It scares me how those things are mounted though.
No matter how secure you get that box installed, it's still hanging by two little 8-32 screws though little sheet metal tabs.
