What is your house made of, dumbass? 😂
There is only compression loading on the oak crane boom. I could've used a bunch of paper towel rolls wrapped in duct tape.
I AIN'T TRYING TO LIFT ANYTHING WITH MY HOUSE......
1680465314822-jpeg.87782
But, it wouldn't be able to move. What good is a gantry if you can't move the load?
Who says you can't put wheels on it?
OK I guess I'd need 5 pieces of telephone pole so it can have 4 wheels.
But without wheels, it could be used for loading and unloading trucks.
Hang the load, back the truck under it, lower the load.
I seriously want to build a machine of some kind. I built a hand operated crane and that was fun, but I want to do something with motors, bearings, shafts, belts and pulleys, etc.
I'm almost dead set on building a sawmill. The band saw type, because the blades for a circular one cost a million dollars.
I have a 23 hp V-twin engine from a Cub Cadet mower I can use. 🤔
I need to find a deal on some steel beams.
hey numbnuts, it ain't like my house is bench pressing.........
AMWts8DQASu6r3vJG12Y-ML_DaHI2uzeX47VjwIAm9kKZUbefpQkWCKZe47yzJoGm51Bdb45M0QSlnucLk46C1uzPmYEZ1g0H26nDqNKhUCMZPa7-Eooca8MILuI22NnpbKegXtEgJUCt1soW_3anyiFyBhZtynNFL8Mb6OSVXValLI8fAoX11-LN_Eh3St79ItxsLkeiR-tnhJJi7xAnErtZW3WbtPf0nmOH1P-Mly-4umMNtHvEHu5H3PlARJLM2zf67yczWWJR9kCAyzS0YSrJ7e-g3bvcVbeyt5wkeqsemfwex2Ytk-dR0GVJZh-NebVxTxVAl0x-ZrnHc0nvP29uq1lQEMDWCN8QZvs9sg_Vd8tQv-5VXILyrSsLyM5UegzTpfXrnGshzROsw89555Ct0FMW1eCHxkfsRLpqpPNqTmqWhc4tXolfGbd8TZzuRAJKC12qIA39O0rALDBkkzPvKAdvyLzEYTDqrBJfOWXmcuoAkH3gTJNMVrf-pzyHl10BSG3Jx4v-9sh9QKlDjQv7O1DadbOMgbNVYXbMZAokdf1GJjFViMBPRlfQML3WiZpP31ACXPyHIeUiH-H3qtziblWu76-VBXh5D1_oOdp6uZOeg_zwvMg3W-YUCqnnHURRAMdsURnh85mCK3rOVPolfTdXYQLAFKyrbYVRoGDaa5Ij1CsLinBevdV9GN_iWj0N-OxUOgVym9hOtzsalxdaUUvmCOmCc4lp0_if0YEiqRGwRN7tZlaYpN7ZjEOc0rkgQY7-Oj0d8AL3QecJ1I8NrEDDHaHT6rB4E3YU9rOZ8C7KVgXyifEAYf0eyY8skCoi45uAte4ISx3o5b5OVnZAST9bvwNmsEquL7ChHpygvBJ-tH5PCwuboIieOr1xzFcKOIYDo4dwXNkpJeTotvD7wctKw=w600-h316-s-no
You aren't a structural engineer, either. You have no idea of the load that is put upon roofing joist or joist that has to support a second story, be it frame or block. That joist is actually bench pressing.
i'll put my homes joists, thick as they are, made well over 150 years ago, to @Duck 's toothpick crane.
i ain't gottabe no damned engineer, to see the results after several liftings of that Rube Goldberg contraption.
Okay, so you need a stationary crane. I have an engine hoist capable of lifting an 8V-71, but you are too far away and I don't deliver. I don't even think I could put it together anymore. This damned thing is heavy.
I'll most likely put in an overhead gantry crane when I build my dream shop. One with a motorized trolley so you can pick a cab up and set it down in the next bay.
It's designed to lift less than 50 lbs but I hung from the end of the boom with my hands and I'm 240 lbs.
Maybe I should have used a piece of bamboo instead.
