Adhesive event recorder. It sticks to the skin as opposed to the small implantable one that goes under the skin for longer studies.
It's a single location instead of the multiple sticky pads with wires and an electronic thing worn on the belt called a Holter monitor.
So what you're saying is you're not an adhesive event. Poor Sarah.
Well I shipped that heart monitor to Pennsylvania Friday, as instructed by the cardiologist.
Hematologist says there's no hyperglobulance. Blood not prone to clotting. I don't know if that means I can stop giving her aspirin every day.
Epilepsy got worse. 2-3 seizures a day for over a month, but after a few tweaks in her meds by the epilepsy neurologist, it's been 5 days without a seizure.
Blood pressure is still running low except now it's spiking as high as 140 and dipping as low as 77. And it's vascular tension. Pulse is pretty steady (and low) even during the spikes. Vascular tension is controlled by a part of the brain that was damaged by the stroke.
All the other parts of the brain seem to have recovered though. So this is weird.
I have no words but appreciate the update. Hopefully it gets figured out.
I made a big hole in the bathroom floor.
Squirrels filled the plumbing roof vent with walnuts.
Can't access the bottom of the vent pipe from the crawl space. Can't get past the main pipe. Only 8 inches between the top of the pipe and the floor joists.
The shop vac hose fit perfectly into the rubber thingy on the vent pipe but it wouldn't suck out the obstruction because for some reason it's a 4" pipe at the roof, but necks down to 2" somewhere in the attic which is not accessible.
So I reversed the shop vac and blew the walnuts all up onto the roof. 😁
You need to cover the vent stacks with a fine wire mesh.
I have a metal roof on my house with a 32 degree pitch. The squirrels try to get up there and just slide right into the gutters. It's funny as hell to watch.
I've been thinking about making (or buying) some kind of little bird house type of roof to go over it. It'll keep rain out too. And those little helicopter seeds from the maple trees.
Rain is okay, it helps to keep the walls of the pipe a bit cleaner. Plus, it just goes to the tank or the sewer. It's the solid stuff from the rodents that gets expensive.
H/D may sell you a foot or two or some chicken wire. Tie wraps or worm gear clamps will hold it in position.
I don't think wire mesh would last long. I put it over my PVC boiler exhaust thing to keep birds out but it rusted through in less than one winter.
I ended up making a cover for it out of a plastic floor drain strainer.
Maybe I can do something similar with the plumbing vent.
The vent pipe is steel. Probably was galvanized. There's lots of rust on the inside. I think keeping it dry is best.
From the big pipe, it's plastic up to about the max height water would ever get up to unless it's clogged.
interesting
Old @Duck is the "Real" Deal "Redneck..
He lives out in Country on a farm in Kankakee County..
Out there ya can do stuff ya can't do in a city or town..
Heck awhile back Town of Winthrop Harbor was on my @$$ didn't Pay for a "Permit"..
Windy Harbor also shared that with "Lake County" so I got "Double Burned" hadda pay "" Fines" Both Town & County..
In "Protest" I left "Exposed" Tyvek for nearly 3 years .
Eventually I got sick of looking at that crap ...
Paid my "Fines" dropped Court Case pulled "Permit" for Improvement
@Duck is SAE Red Green.
I sued em in Court using a "Statute" ..
They dragged this On & On..
Should've "payed" the Fines "Upfront" and pulled the "Permit"..
My "Attorney" Fees ended up being 5/6 times in "Excess" of entire Project Co$ts..
Plus they kept "Stalling" like they were trying 2 "Break Me"..
I dunno so far this house so fixed up I should be "Dead" before it needs anything else other than "Simple" Maintenance..
I'm still "MAD" though in My Folks left me this house payed it off Decades ago...
But to Fix Up ya gotta pull a "Permit"..
Not to "Mention" the $3 Grand on "Property Taxes" I mail em a Check every YEAR
I'm still "MAD" though in My Folks left me this house layed it off Decades ago...
Make that $4258.39 this years "Property" Tax Bill..
If I don't mail the "Check" they'll send "Sheriff's Office" to "Evict" me..
Then $ell property cheap at Auction get their "Taxes" First
Gained "Value" but to $ell and Move means "Buying" Another Place probably much More "Expensive" than just Staying "Here"..
Plus Over last decade I've fixed up stuff this house should LAST Me until I "Die"
My property taxes shot up like a rocket too. It's in the escrow on autopay though so I basically just keep getting poorer without noticing.
