I took off in Blueford to go to Farm and Fleet to get some light bulbs for it and got about halfway to Manteno and it died.
Found On Road Dead...
Didn't sputter or anything, it was like I'd turned off the key.
Geezer came out. On the $&#@ing Goldwing.
I left him there, rode Goldwing home and went back with the S-10 and flashlights, tools and chains to drag it home with.
Removed air box, sprayed starting fluid into carb while geezer cranked it. Nothing.
Pulled front spark plug out and had Geezer crank it & I saw a spark.
Just for the hell of it I put it back in & had Geezer crank it again while I sprayed ether again while holding the choke open and it half-started, tried again and it started up and stayed running long enough to put the air box back on, put tools away and drive it home.
Big air bubble in the fuel line?
Carb float stuck closed? The engine rocked in its mounts during that half start thing, maybe that loosened up the float?
Tomorrow I'm gonna replace the little fuel filter on the carb and while I've got the fuel line off at the carb, crank it & see if it squirts gas. That'll test the fuel pump. Otherwise I ain't got no idea.
