An 8-32 screw, 3/8" to 1/2" long threaded part, with a 3/8" wide, 3/16" thick head, cut for a flat head driver, with a concave bowl shape on top, and a tiny hole about 1/32" by 1/8" deep drilled into the center.what part needs to be made?
The tractor forum guys say it has to be brass but didn't say why. I'm guessing it has to do with dissimilar metals. Galvanic corrosion.What's the hole in the middle for? Does it need to be made out of brass? Mail it to me and I'll have our machine shop make you one
on the screw, i think you can use a dab of anti-seize on the threads. you "may" get lucky at a junkyard and get an old points distributor and get the screws from that.Goes here. Red arrow.
Ignition coil rests on top of it and it has to be bowl shaped to center the spring and guide it into that little hole.
Take it you've never played with fire colors.Note to Self.... Never mess with Mndriver!
Mine sounds like a Toyota forklift. It's a 4 cylinder, designed to run at 1500 RPM.I think those old tractors sound cool. It's like they are ready to stall out all the time but keep going
some peroxide on either a Q-tip or small paint brush, will clean up that gunk on that spring.Goes here. Red arrow.
That's the old 6 volt coil. The 12 volt kit came with a new coil. But it's still in the box and the old one was right there so I took a picture of it. It's the same spring though.some peroxide on either a Q-tip or small paint brush, will clean up that gunk on that spring.
oh..ok...you can still give it a light coating of dielectric grease, just to keep it clean...if ya wanted to.That's the old 6 volt coil. The 12 volt kit came with a new coil. But it's still in the box and the old one was right there so I took a picture of it. It's the same spring though.
Yeah.oh..ok...you can still give it a light coating of dielectric grease, just to keep it clean...if ya wanted to.
actually, i meant to say put some dielectric grease on the new coil.....Yeah.
It might be fun to play with, using a 6 volt lantern battery. Make a stun gun out of it and run through a crowd of protesters.![]()
