Sarcastic remark goes here
Yeah. Inside your truck where there's no room to stand up.Your not 6' tall. I MET YOU!!!!!!!!!!
Dumbass.
Dude the air seat was all the way down.Maybe if you put 5" lifts in your boots!
6 hours later he's bitchin that he didn't get enoughThe agony of small hand syndrome.
I figured two 3 foot rods would be enough.6 hours later he's *****in that he didn't get enough![]()
why do you need that 3rd light bulb.>??...which isn't even turned on..????Starting to look like a workshop instead just a big chip-board room.
But I didn't get enough 1/4" rod for the pegs.![]()
I put that up there to see if it's worth the trouble of cutting that conduit to install a middle light fixture.why do you need that 3rd light bulb.>??...which isn't even turned on..????
as it is, you really should have bought the LED's in a clear lens, to give off more light.
for instance, in all 3 of my apartments, we have ceiling fans. each fan has a globe, that is frosted. you simply cannot put a frosted bulb inside of a frosted globe, as this cuts down the light's brightness.
so, in each ceiling fan's globe, we have clear lens LED's..better lighting.
right now, (as of this upcoming weekend) i will be shopping for LED 40 watt shop lights (in a fluorescent style tube), for my workshop.
seriously, to get a wider, brighter coverage of those LED's, get clear lens ones, not frosted, unless you need frosted for table lamps that have a lamp shade....
new axle for your fart carI upgraded the wheels for my battery booster. Got tired of it bouncing around all over the place when I'm pulling it. A long time ago I extended the handle to stop it from running over my heels.
I've seen better wheels on kids toys.
Now it's got push lawnmower wheels.
My arc welder is like that.the battery charger i had in my garage, had real rubber tires. damned thing was already something like 20 years old, when i went to work there, weighed more than a '66 Lincoln with suicide doors, too.....
