We had 3 of them at the last job I worked. Got to drive one a few times and liked it. Braking is so smooth. A different feeling all together. Takes off like a rocket too.
look back at the compressors, then take the Briggs and come up with a power washer, need one for under my 5th wheel etc. oh yes I can go straight to a store and buy one, same with a compressor, but, I wasn't raised that way.
What are you talking about? Trying to pump water with the air pump (aint gonna work), or filling the air tank with water & using air to force it out?
I have a 5 HP pressure washer. It's like 2500 or 3000 psi or something.
I'm talking a Redneck power wash(homemade), did you make yours?
I try not to run to the store for everything that's what I meant by I wasn't raised that way.
Nah I just ran to the store for it.
It's got a 5 horse vertical shaft briggs engine.
I used it twice & then drained it & put it away.
While I was out trucking, my dad came & stole it, used it and didn't drain it before putting it back. That winter the water in it froze & split the pump open. I was pissed. So pissed I can't even stand to look at it. I bet the engine is seized up by now. Damn thing was brand new. :mad:
While I was out trucking, my dad came & stole it, used it and didn't drain it before putting it back. That winter the water in it froze & split the pump open. I was ****ed. So ****ed I can't even stand to look at it. I bet the engine is seized up by now. Damn thing was brand new. :mad:
That Sucks
I thought I would point out that you could tuck your smokes between the visor and the roof. I have done that for years. The T680 comes with a space in the dash that fits a pck of smokes perfectly. I am not sure if that is what it for but that is how I use it.
Putting them between the visor & ceiling would prevent the visor from being used for it's intended purpose though.
The truck also only had one 12 volt outlet up front but I solved that problem last week with some top quality hillbilly engineering. :D
:worthless_thread:
The piece with 4 holes is one of the rectangular knock-outs from the circuit breaker panel in the barn, that you have to break out to install the breakers. :rolleyes:
Oh, and that's not even a coat hanger weld. I used rusty baling wire. :D
