Life in Sector 7 G.
I am so pleased with myself right now and this is a rare moment.
Sunday my G.D. dishwasher stopped working and was leaking water. I was super pissed because I just bought it 6 months ago. I was seeing red and not thinking right. I had to take a step back for a couple days.
Thanks to the good people on the World. Wide. Web., I found some possible solutions. One of them worked! I fixed it.
Suck it Libraries!:tongueout:;)
Okay so here is what happened with washy, washy dishwasher, Samosas!
Ya, some hard potato pieces some how made their way past the filter and into the drainage system.
When I got this dishwasher the rubber washer got away from me so I just used the one from my old dishwasher. I was lucky enough to find the new rubber washer twice. switched the rubber washer and the dishwasher works again saving me $500 and not having to soak my dishwater hands in Palmolive.
As it turns out the old rubber washer is the same size in diameter but the center hole is smaller.
I can't help but feel partially responsible for this malfunction. ;)
I keep forgetting this is not Twitter and I can use as many characters as I like.
La,La,La,La,La
You must be one of those that puts the dishes in the dishwasher without at least rinsing the heavy stuff off.
I am one of those guys. They say you don't need to do that.
In 20 years never had a problem. This time....problem.
I will exercise better practices going forward.
I am just happy I got it working again.
I guess being on a septic system just about all my life, you have to do things differently than with a city supplied sewer. You pay attention to what goes down the drains. You wipe the excess grease off things before washing, put food scraps in the garbage, never use an in-sink disposer, stuff like that. It can really mess up the tank, drain field and the pipework carrying the waste products. Grease especially. It floats on top of the tank contents and solidifies. That in turn will build up on the outlet from the house to the tank and block it, causing back-ups in the house.
You then need to call the plumber. He comes out with the snake auger, cleans the pipe in 5 minutes and charges you $200. And invariably, this always happens on a holiday when the price doubles and you have people over for dinner.
Do a really good thorough cleaning of the pipes if they're PVC. Replace the pipes with PVC if they're old rusty steel without a smooth inner surface.
Once you have the pipes clean, like new, remove the stupid linkage rod that opens & closes the drain plug because it interferes with the flow. You want to be able to simply grab the plug and remove it and look in there and have it wide open to the trap.
That way you can periodically flush out the pipes.
You do that by filling the sink with water and then pulling the plug totally out & let the water flow through the drain at its maximum ability.
Letting water trickle slowly through a drain is what let's shit accumulate on the inside of the pipe.
Same thing with the shower.
Hair used to wrap around the stupid linkage rods inside the drain that raises & lowers the plug.
I removed that shit and the shower worked perfectly fine for months until my dad came & stayed a few months and fucked it all up by putting a strainer over the drain with the belief that the strainer would keep hair from clogging it up.
The problem is the strainer slowed down the water to a trickle, allowing soap scum to accumulate in the tub until it was later rinsed into the drain. Soap scum then built up on the inside of the pipe until it would barely flow.
I got into the crawlspace and cleaned it out and it works fine, as long as there's nothing to slow down the water at the tub drain.
Yes the hair will eventually need pumped out of the tank but I've been in this house for 19 years now and have never once needed it pumped out.
The field tiles are intact and go out for hundreds of feet in several directions.
I can see where they are during mid summer drought if I climb up the 50' concrete silo and look down. There are lines in the ground that will be greener.
About 6 months ago Mom ordered a treadmill, So I went over and assembled it.
Thinking, I doubt she will use this. It took me like an hour to put this contraption together.
Today she asked me to get it out of her place.
Now i know how she feels about the money spent and the sports I quit when I was a kid:oops:
There's something about treadmill motors that makes them desirable for mechanical nerds but I forgot what it was.
I am going to have to restart my Netflix subscription because they have this new series Dahmer. I mean who is not interested in an inside look at this psychopath?
I hear the soundtrack from the 90's is awesome. Just judging from the trailer it is creepy as fuck!
I hope this link works.
Edit. Damn it kinda works but you got to scroll down and hit play on the trailer. Sorry folks, I don't know of any other way to link the trailer.
I finished Dahmer on Netflix. Ten episodes 50 mins each.
It is not in chronological order, I assume so they could make it longer than it really needed to be. They go back and forth kinda making it more confusing than it needed to be.
It is pretty good but leave it to Netflix to slip in some wokeness in there.
There are scenes where Rev. Jessie Jackson appears go to Milwaukie. I just fast forwarded it through that part because I can't stand the sight the POS. I am not interested in anything the POS has to say, So I skipped all that.
Despite what the Rev says Dahmer was an equal opportunity killer!
Damned if you are inclusive and damned if you're not.
Yes I think Dahmer was also a POS don't get me wrong.
Hard to believe this was 30 years ago. Watching this reminded me of a lot of the things I had forgot about during that time. Hard to believe how many times he was so close to getting caught but didn't.
My first time vacuum sealing, unthawing and cooking breaded fish.
I have learned that you don't want to stack fish filets in any way. They will get stuck together and nearly impossible to separate without heating and creating a mess of batter.
Lesson learned!
Sure I could take responsibility for this mishap but, climate change seems to be a more popular way to go and so I am going with that.
Dinner is f'd up because of climate change.
What I will do will these fish fillets is spray them with some oil and cook them anyway. They will be missing the breading on some parts, But I am not going to waste them just because of some freezing/breading issues.
Waste not want not.
Lesson learned!
I got some romaine lettuce for no reason other than to vacuum seal it & see what condition it's in 6 months from now when I decide whether I wanta grow lettuce or not.
I'm waiting to see The Munsters movie.
Saw it last night. I wasted an hour and half of my life that I will never get back. Birchy's videos are better!
Lesson learned!
Put waxed paper in between the layers, or section the bags to hold 2 fillets each. You can cut off one if that's all you need and the other stays sealed.
It will be a slimy mess when thawed. I ruined some good scallions that way. :mad:
Are you sure about that? Scallions are basically green onion. Aldi sells green onion in vacuum packaging. It's cold but not frozen. I've frozen it and thawed it plenty of times and it wasn't soggy or slimy.
I've got green onion sealed & frozen in the freezer right now and I've been using some too. The stuff I simply put in a glass jar is all frosty though. Just means it'll be wet when it thaws out. I just take it out of the jar and put it in the pot with other stuff and stir it in.
When I open a frozen, vacuum package of green onion, I'll either re-seal the unused portion or cut it up and put it in the jar.
This is romaine lettuce I'm talking about though. I've never tried freezing it, or vacuum sealing it.
I still have several packages in the freezer. I don't know what I did wrong. I cut the very tops off, vacuumed sealed them, dry, no residual water from washing, then placed them in the freezer. The first package that I opened to put into a marinara sauce, (I use the white bulb part) was mushy. Not firm and crisp like I was expecting. I used it anyway because it was going to be cooked down and then, chopped up the green tops for toppings on baked taters and such. The flavor was still there, just the texture was wrong.
