CMT
My front right hub has been leaking for a few months now. I originally suspected the wheel seal but have been told twice by 2 different shops it's the plug and not the seal. Both times the plug was replaced and the leak seems to stop for a few weeks then starts again.
I took it in last fall to a Petro that I have trusted over the years and was told it was the plug & not the wheel seal. They replaced the plug and it didn't leak for a few weeks after that. I figured they were right because it went a while without leaking again even tho I've never had a bad plug before. Needless to say, it started leaking again. I asked another mechanic at a different shop and was told again it wasn't the seal, but the plug. Same thing.. plug was replaced.
I'm constantly cleaning that rim as to not draw attention to it, plus any exterior moisture makes it look worse than what it is. I need to get it to the guys in the shop that I trust the most, but it's just a matter of timing with having to drop my truck off with them. The lube inside the hub almost appears a bit rusty. I'm a stickler about maintenance and have never let the hubs run low or dry. I'm currently using 75w 90 in them. Could it perhaps be the bearings causing the issue here? Or maybe 2 different mechanics were wrong in their diagnosis? Any input you all can offer is greatly appreciated.
