ISX15 rebuild issues.
Hennessey
I have a Kenworth t660 with an 1sx15 that was rebuilt by Kenworth 2 months ago. Just this Friday, I developed a small oil leak, and took it to them. So far, I was told that it was the crankshaft seal and the oil pan combined that caused the leak. he oil pan is covered under the 1 year warranty that Kenworth offers, but not the crankshaft seal. However the seal should have came with the rebuild kit (I'll check on this tomorrow from Cummins). Need some advice on what I should do
Crank seals are not normally changed during a rebuild and are not included in rebuild kits.
Oil pans get diagnosed as leaking quite a bit because any other oil leak on the truck ends up runnign down the pan rail making it seem to be leaking.
Oil pan gasket will be covered under warranty but its more of a workmanship issue if it was just off 2 months ago and leaking. Either way you shouldn't pay for it to be fixed.
Front or rear crank seal?
Drove the ruck probably 300 miles and parked it. started it up again and ran it for a while. stopped it and now i have a good sized leak under the truck. And its oil again. I can see where they tried to use a white sealant but yeah what would you do?
