King pins.Each brake s-cam
Each brake slack adjuster
Spring at each end
Clutch pivot points and cross shaft
Drive shaft ujoints
Steering shaft ujoints
5th wheel
Just a starting point for there.
Paccar product?I do the u joints every week
No they are spicer joints, but heavy loads really work on them. I used to grease everything at 10,000 miles, but when I went to heavy haul I started having joint issues. I’ve had much less problems since I’ve increased intervalsPaccar product?
Greaseless joints. Now that's a joke.My meritor joints are greaseless.
My century has 1.3 million miles on them and I see no reason for the Volvo to go that far as well
Joke all you want.Greaseless joints. Now that's a joke.
Depends on the procedure according to the manufacturer. Hendrickson airtek you can't do thatDon't forget to jack up the front axle to get the pressure off the kingpins when you grease them. If you don't the grease won't flow around the entire pin. If you have the special style with the grooves cut out then ignore my advice and don't bother jacking it up.
No wonder your trucks fall apart. Install zerks, get a grease gun.Joke all you want.
Haven't had to grease a joint since 2012.
RtfmSo you "cant" do that on a Airtek steer huh? Why not?
No matter how I answer either of you it will get torn apart.So you "cant" do that on a Airtek steer huh? Why not?
Well... yeah. It's called they bet that on the average use of 350k - 400k per truck, the schmuck who is the 2nd owner will pay the cost of dealing with that. Don't forget there's stuff like greaseless slack adjusters, S-cams, etc, too...There's got to be a statistical reason why pride continues to spec their trucks that way.
Sure....Well... yeah. It's called they bet that on the average use of 350k - 400k per truck, the schmuck who is the 2nd owner will pay the cost of dealing with that. Don't forget there's stuff like geeaseless slack adjusters, S-cams, etc...
I'm curious as well.So I ask a simple question, that should prompt a simple answer, and this is what you came up with?
I wasn't trying to tear anyone apart but I guess I can if that's what you were wanting. If you were afraid of getting torn apart then why did you bother posting anything about a big ol "airtek" suspension to begin with? No one else mentioned it but you.
