Electric Chicken
Fo sho. Still trying to come up with some last minute excuses. Suggestions welcome.Getting serious!
Thanks. I'm cautiously optimistic. It'll either do me good for a while or just give me a chance to see where my revenue is for something better.Good luck with it!
Lol what? The rust, or the fact that it's upside down?
I think you should postpone it until you figure out a way to prevent the tires from getting dirty.Fo sho. Still trying to come up with some last minute excuses. Suggestions welcome.
Good idea!I think you should postpone it until you figure out a way to prevent the tires from getting dirty.
I think it's because their safety guy/department is there. Only reason I can think of. Kinda surprised me too since they're out of Virginia and run us on PA tags.i knew you'd be back, even "Arnold" said so, in my last posting.
good luck, i wish you well.
But why a MA, IFTA..?????? you live in Pennseetuckyland.....
Drilled through the flange.Lol what? The rust, or the fact that it's upside down?
It's been improving since I've been using it for more than just wheel holding (IOW strengthening) but I don't think it'll ever get to a pre-injury state. My collarbone is basically dislodged.Shoulder gotten better?
Hadn't talked about it, but I screwed mine up a couple months ago. I blame @mndriver. Only because he met me a few minutes after it happened.
Didn't think much of it at the time, did it while replacing a fuel filter really quickly out in the cold. Felt something feel like it tore. Just made it worse for the next few weeks working, then at home trying to do things as if it was fine. Finally let the wife do the heavy lifting around here for a few days, and actually put the arm in a sling off and on for the past couple weeks. Turned out to be a blessing that I shut down a couple weeks ago to let this thing heal. Still not 100%, but good enough to drive an auto shift next week.
Ah. Pretty sure the deck plate is the same way. I didn't put that bracket on. It had the PTO tank on it.Drilled through the flange.
What were you really doing in the rest area?Shoulder gotten better?
I'll never tellWhat were you really doing in the rest area?
Did you write all those numbers down?BTW my dad helped out. He insisted on putting these belts on for me. Water pump was near shredded but noticed the others weren't so great either. So now all 5 up top are brand new.
Alternator belts way down low already looked newish but I've got new ones coming anyway just in case. They're separate from the rest.
7 belts in all.View attachment 76969
Yes I did. All by myself.Did you write all those numbers down?
To use a quote from Chico and the man, "looking good!".Last minute spray bomb frame paint job. Not perfect but better than it was. Need to work on the details this spring.
In like flynnI think it's because their safety guy/department is there. Only reason I can think of. Kinda surprised me too since they're out of Virginia and run us on PA tags.
StalkerIn like flynn
gl
Ok I give up. Looked at DDI website read some reviews, saw the pros and cons
even backed track here a tad.
What the hell does DDI stand for!!
Direct Divergence Intermodal was the closest thing I found, no?
