You can tell a torque stick is working anyway because it'll sit there and hammer then stop. And it has like a feedback chatter distinct from the hammer and the socket on the nut.
Most are rated at... aw nevermind
My half inch "earthquake" impact is rated for 90 psi. I've never once run it at 90.
But when I feed it 155 it'll kick some ass.
The MFer snapped a rusted 5/8" bolt (15/16" socket size) when I was removing the aftermarket bumper from @Blood's green Freightliner to make a new mounting bracket for it. (It was loose and wiggly when he bought it because one of the brackets was broken .)
The MFer snapped a rusted 5/8" bolt (15/16" socket size) when I was removing the aftermarket bumper from @Blood's green Freightliner to make a new mounting bracket for it. (It was loose and wiggly when he bought it.)
Yeah my compressor is 115 psi and I let the guns have all of it. For better or worse. Lol
I'm under no illusion that I'm actually getting 1800 ft-lbs. But I don't need 1800 to make the stick work. I just need more than 475.
I can goose the nuts without the torque stick and they'll move some more. So yes it's working.
The way I have my air shit set up, if I need a regulated line I can open the door to the electrical closet the compressor is on top of, and I've got a regulator on the wall. But the hose reel, the line going through the ceiling to the blow gun by the drill press and the one going to the unheated side of the barn for blowing grass off the lawnmower are unregulated.
I only put the regulator in there thinking some day I might want to use a paint sprayer or something.
I've heard too much pressure can ruin your air tools but I've never seen it happen. I don't think I'd let them have more than 115 though anyway.
Low CFM is fine for short bursts. What I'm wondering about is what kind of pressure do the big guns need? A truck is typically set to cut off at 120.
My compressor in the shop goes to 155 but I run 3/8" hose and Milton M type couplers.
I would upgrade the hoses if I needed to but I don't work on trucks or big farm tractors and don't own any tools that need massive CFM anyway, so..
In our shop and on our service trucks we run 3/8 hose on 1/2” and smaller tools and 1/2 hose and fittings on 3/4” tools. I run my 1/2 Nitrocat on my my truck then hook it in the shop and it’s a totally different animal.
90 psi. My issues are strictly with runtime, not power. It's annoying but it's cheaper at this point to take a little extra time than buy a $1000+ compressor.
CFM is your problem, and ill guarantee that is not putting out 1800 FT-LBS. especially at 90PSI. Put it next to a Snap On or even an IR and feel the difference
If CFM is my problem, a Snap-On and IR will be equally weak. Go ahead and argue that one.
I also have the 1250-K and that sucker is beast. I love it. So light and packs a helluva punch.
Once again already addressed the torque so not going down the rabbit hole.
I have four half inch impacts.
Three of them have the triggers stuck in. As soon as you connect the hose, they're going full blast.
Makes it a real pain in the ass to use. I even rigged up a short whip hose with a ball valve on it until I ended up just getting the harbor freight "earthquake" one.
I figure the stuck trigger valves is caused by not using them often enough. (I oil my air tools every time I use them.)
One is a Blue Point, another is Campbell Hausfeld and the other one is Snap-On. I might have an old Ingersoll Rand too.
Definitely from sitting too long. You're supposed to oil them daily regardless of use.
A guy on youtube took one apart and it was rusted to hell inside.
Yes a Snap on or IR will be weaker but not equally weak. I wasn’t talking about CFM or PSI when I said that I was talking about raw power at requisite PSI.
Is it the orange one or the newer black XT one? They're both pretty beastly and highly regarded.
MAC always had the most kickass air tools when I was in the shop. Nothing matched their power back then.
Some dude on YouTube has a Skidmore-Wilhem and he compared my 1/2" Nitrocat with different guns. It's been a while since I watched it but he used the same hose and fittings I have but has a bigger tank. It got near or more than what it was rated at. I forget which but it was impressive. I have no reason to believe mine isn't doing the same when it has full air, nor do I have any reason to doubt the claims they make on their 1" gun.
