Something will break the way you had that set up with the bottle jack. Either the nuts or the breaker bar. Or the bar will slip off the jack head. It's likely to go flying if it breaks at the pivot point. Definitely take cover when you operate the jack.
You do realize that was like, 10 hours ago, right? I mean I'm not still doing it. The second photo shows the wheels off. 😂
It's like when Birchy gave me purchasing advice on a truck after I already bought one. 😃
What actually happens when it falls off the jack is it kinda tips over slowly and goes plop.
I know this because it happened like 5 times before I gave up.
I still have a fully intact breaker bar, extension, socket, and human body.
So you would be incorrect.
At 7:40 pm your time (well after dark) you said:
Someone must have just way way waaaaaaaay overtightened the passenger side. I mean I had a 20 ton bottle jack pushing a breaker bar and they didn't crack.
Figured you were talking about the inners, obviously, some of which are still on in the bottom pic.
I figured you were just drunk.
Everything on that side has been broken loose and the studs that didn't come off with the nuts have been retightened. It just took way more effort than it should have to do it.
Compared to the driver's side on which all 20 nuts came loose with the 1" impact and not having to wait for the compressor. When the air ran low it still hit hard enough to move them. Then it refilled in time to get the next one. Being that easy is why I'm skeptical and will make sure the inners are good before rolling.
Nah I got all those loose. I'm not rotating the inners. The only ones not on are the ones that came off with the nut and are still stuck in the wheels.
I was referring to the past struggle relative to the driver's side. The passenger side you're looking at took a ton of effort. The driver side zipped off without waiting for the compressor. Which is why I mentioned checking them before assuming all is good.
What did you decide regarding the use of anti-seize on the studs when you put them back on?
There is a lubricating effect because it's like a grease. This will reduce thread friction, enabling the threads to turn further and squeeze harder on the rims with the same amount of wrench torque.
Theoretically it could stretch the studs.
However it's all theoretical and with millions of cars, trucks and stuff on the roads for a century, we would have more than just theory to go on if that was a problem.
What I would do is put a small amount on the studs but make sure there's on the part of the nut that seats into the rim because you don't want or need lubrication there. Then simply don't go over the torque spec.
I thought truck lugs were supposed to be 450 ft lbs but someone said 600? :dunno:
It has some on the inners studs but I'm not sure whether I want to use it on the outers. I'm a little leery about doing that. I feel like maintaining it and not neglecting it is all I need to do.
450-500 is the spec I keep finding online for Budds and that's what my 1/2" hits on the middle setting. So that's what I'm gonna go with.
Decided to go ahead and run 'em despite the imperfect paint. I like them not being black but I'll redo them after I paint the truck and match them up. I think it'll look sharp especially with the frame redone in black.
View attachment 73613View attachment 73614
It definitely looks better with them red.
If it were me, I'd put some surface mount tail/brake/turn lights on that tail plate if I was going to be bobtailing a lot.
It's cool they put a pintle hook on it.
Other than the mismatch with the body color, I like it too.
No need. There are lights right above it only a few inches back.
I like the red Mudflap hangers. Black would look too generic.
Maybe get some red mudflaps too for that custom look.
