Oxbow
Little tiny beads that are put inside your tire to work similar to centramatics.I do need some education here. Beads?
According to the googleator...I do need some education here. Beads?
Oh I forgot about those. Think a dead squirrel would do the same thing?Little tiny beads that are put inside your tire to work similar to centramatics.
Above my pay grade.I don't get how having weights that fling outward to seek out the furthest point from the hub on an out of balance wheel wouldn't just make it even more out of balance.
Yeah I decided they're all gonna go and it's getting a new set. Most likely virgins.Think I said it before, a tire that is out of round will not balance. no matter how many weights you stick on it. if the truck sat for a very long time you will have flat spots in the tires. they should work out after you get some heat built up in them. or just rotate the outer tires 180 to separate the spots. are they recaps ? or cheap china tires ? if so, good luck throwing weights on them !
The supposedly find the light spot and counteract the heavy spot. I’ve used centramatics in the past. I couldn’t tell any extra tire life or better ride. I think they were invented by the turbo 3000D guy or the aircell guy.I don't get how having weights that fling outward to seek out the furthest point from the hub on an out of balance wheel wouldn't just make it even more out of balance.
Hankook makes an affordable tire that last. Uniroyal does too, but they aren’t good if you go off road much.Anyone have any drive tire preferences?
Accepting recommendations.
So if he just goes truckin' for a while with a loaded trailer, it oughta even out the flat spots?if the truck sat for a very long time you will have flat spots in the tires. they should work out after you get some heat built up in them
Seems to me it could if the flat spots come from settin and not dragginSo if he just goes truckin' for a while with a loaded trailer, it oughta even out the flat spots?
Only half of us know what we're talking about.Didn't y'all tell me I could burn out my wheel bearings if I did that?![]()
It'd be a whole lot easier if the ones who didn't know what they're talking about would identify themselves before they gave advice.Only half of us know what we're talking about.
It's up to you to figure out which half.![]()
I told him thatOnly half of us know what we're talking about.
If its from settin it should go away pretty quick once the tires get warm from a good load on ‘erDidn't y'all tell me I could burn out my wheel bearings if I did that?![]()
I'd say it's from sitting. It doesn't look dragged.If its from settin it should go away pretty quick once the tires get warm from a good load on ‘er
