The heaviest truck I've ever driven was an overloaded Van Wyk Volvo or KW T-660 (I don't remember) that I took from Chicago to the big Menards DC a few miles east of Omaha. Listening to the engine moaning out it's one note song, yada yada, etc
It was a load of shingles I picked up.
Not only was it way over gross, they loaded it in two separate groups of pallets with nothing in the middle because they were used to loading flatbeds with a frame. No idea why they agreed to load a reefer. No idea why I decided to pull it. I guess I figured, well if I don't use the brakes, I'll be fine. 🤠
I scaled it somewhere and my gross was 91,000 or so. As I remember it after all these years..
I took 90 out to Rockford and took US 20 across most of Iowa, then 2-laned it down to I-80 to avoid the scales south of Storm Lake. It added miles and time vs I-88 to the quad cities and 80 the rest of the way. But I would have wasted even more time had I gone back & made them cut the shipment by approximately one fifth.
The truck wasn't that much different on the Illinois section of US 20 where it's hilly just like most of Pennsylvania. It had enough power I probably coulda had another 10k, but the Jake brake wasn't much help on the down-grades and I had to do the whole "mountain braking" thing a lot though. No big deal because I was running Sandstone in WV almost once a week at the time.
But otherwise,... meh..
Just dodge the scales. 👍
My truck actually seemed to like it as far as ride and handling and power goes. Not interested in the fallout if shit hit the fan though.
Dealer closes at 6pm and I managed to get there at 530pm. I wanted to get oil and filters hopefully for a Sunday oil change. If not some random after run when it's warm enough.
I also picked up a new cruise control switch for the steering wheel. The resume/up button is effectively worn out. It only works when I jam it hard with both thumbs, and that's too distracting. My workaround has been to throttle up to my speed or a little above and use the still functioning normally set/down button but that's not always optimal either.
Pretty $alty being Mack and having to get both sides since they're wired together into one plug. But that's basically the only thing that's been bothering me about the truck.
I thought I could clean it with CRC electronics cleaner but that didn't do anything.
That's the adult decision.
Mine was the "young guy who thinks he's got something to prove" decision. 😅
But nothing bad happened.
I started to wonder if my accident load (had the same BOL weight) was actually the same real weight as this one. I didn't scale that one.
It braked liked it was way heavier. These assholes need to learn.
I took it to the yard. It's my brakes and my risk. Not worth it.
Sometimes here we call O/O's brokers, and this is where the "broker brake" comes in. The so called "broker brake" is the "spike" that works only the trailer brakes, so you use their brakes up and not your trucks brakes.
But really if it's overweight, bring it back to get re-worked. That'll learn 'em to load it right the next time!
We used to haul heavy out of Indianapolis and every time I scaled it was dead on balls loaded right.
The one time I did not scale it was loaded wrong and heavy on the trailer tandems. The Ohio scales got me and that is payable right then and there or you don't leave.
I went around after shifting my axles three times, still wasn't right. Scale Master says park it and come inside. Scale Master says just slide your axles all the way back and cross the scale again. We only care about the axle weight not the bridge weight.
Okay but what happens when I get to Michigan?
We don't care what happens when you get to Michigan.
Fair enough. I slide the axles all the way back and was let go. Michigan is weigh in motion so they didn't notice and I was legal in Ontario because they give you an extra 2,000Lbs per axle.
Only cost me $400. 00 American dollars. (so, like a million Canadian) :D
Got home and logged off around 7pm last night. Slept in the truck despite the generator noise for the neighbors. It doesn't run constantly. Don't know if it would be less annoying to them if it did, or they don't even hear it or care. We do have loud train horns frequently and somewhat at random, and we get used to those.
Just didn't feel like going inside for whatever reason even though I started my 34.
Training myself for OTR I guess. Lol.
Looked at a car today. Took it for a spin. Agreed to buy it as soon as my schedule matches getting to a notary to do the title and get a tag.
Say what you want I'll ignore it if it's negative. It's a 2013 Volkswagen CC with a 6 speed manual and 2.0L 4cyl turbo.
I thought these cars were sexy AF when they came out but they were out of my league. In business terms it's about one week of gross revenue so it's not like it's a lot of money. It'll be a cash purchase.
My wife wanted one before I bought the Explorer for her. It was a convertible that lowered back into the trunk with a power hard cover over the top well.
I don't think I could drive a little car again. I can't get out of them. Falling in is easy. I'll stick with a full sized truck.
I don't love sedans per se but a long, wide, and low stick shift that scoots has always been on my bucket list.
Today was supposed to just be a a York pickup from the Starbucks roasting plant but they asked me if I also wanted to run to Virginia and get a load out of where we always go. The answer to that is always yes.
I then noticed when extended one of my airbags had an obvious air leak where it rolls up under itself. When it was sitting flat it kinda sealed itself up.
I got lucky with the scales on I-83 open but didn't want to take the chance again in VA since I'd be bobtail down. So I swung by my house real quick and replaced the bag.
Instead of swiping one from the day cab, which are all basically brand new, I took one out of the scrap pile in the wagon. They were replaced preventatively because they looked sketchy but they were all holding air.
It's only temporary until I buy a set of new bags. It think the sleeper is worth its own new parts after all. I'd like to fix the day cab rather than strip it down.
So this week is our first "oh shit freight has stalled" week since the holiday slam. It hasn't been awesome but I've been getting some acceptably good stuff scratched together with my "yeah I'll do that" attitude. It's been better than what I would get on a regular basis with the day cab due to my ELD skittishness.
I used to be the last minute "don't ask him he probably won't do it" guy and now I'm the "ask him he'll probably do it" guy.
If my delivery for tomorrow was already off the train when I was in there tonight, I would have taken it to York. I had enough time and they have parking. I'm down to stay in it whenever wherever if I can find a place to put it.
I may or may not be a dirtbag for this particular transaction. I liked the car but it only has one fob and the dealer says a 2nd fob will be about $550. Then there's the possible pre-emptive timing chain and water pump.
Stuff I didn't know anything about Sunday and my dad researched and told me about Monday and Tuesday (today).
I'm not a VW expert, I just liked the idea of a manual car because I have a manual truck.
Freight has slowed down this week so having a high maintenance car isn't really in the cards right now, unless he takes a lowball offer.
The weird thing is none of us drivers can figure out if there's actually less freight or if corporate doesnt know how to plan it out.
I know you will ignore comments if they are negative but...I was looking at a VW a few years ago and my mechanic friend told me to stay away from them because the reliability is not what it once was.
I was watching some show, and they had a VW Cabriolet convertible. I was like damn I loved those cars. It must have been from the 90's.
The VW Rabbit was cool.
The VW bus was cool.
The VW Cabriolet was cool.
The VW Jetta was and still is cool.
I think that is all the VW's that were cool.
forrest gump GIF
