Visited my dad a little bit. He set me up with more 6x6 blocks to set this thing on. I also have pallets I can break down and use as "shims" to let the tires roll against if they're out of round. Ie if it's OOR it should kick it out from under.
We'll get this jalopy figured out eventually.
If you need spin them faster, let it idle in a high gear as opposed to using throttle. That way if it falls off the jack it'll stall the engine instead of taking off towards the neighbor's house. I'd chain the thing to a tree or something too.
Yeah it's not gonna be on the jack.
One time I was oiling the chain on a motorcycle. I had it up on the center stand with the rear wheel off the ground, idling in 1st gear while I squirted the chain with oil.
Then when I went to take it off the center stand, I forgot it was in gear.
It took off and put a big-ass dent in the door of my pickup. 🙄
Why am I not shocked you'd do that. 😐😂
It's rear wheel balance. I didn't even get the front axle off the ground yet, but when I spin the rear one forward slowly by hand, it starts rolling backwards on its own after coming to a stop. That means it has a heavy spot.
I might as well take it to a shop and have them balance all 8.
Turn off the engine to eliminate vibration and moving oil & shit.
Also, when they turn from apparent gravity, is the other side turning equally in the opposite direction as it should with a differential?
Finally, clamp a piece of wood or something across the frame rails in such a way that the end of the wood is really close to the tire tread but trailing so if it hits, it won't dig in and break your clamps.
Oh and quit doing donuts in gravel parking lots. It's killing your tire tread. 😠
Lol. I have a makeshift runout gauge from the jack's bar.
I found a flat spot or two in the same tire. Blah.
And yes the differential turns the opposite side like it should. Makes it impossible to tell which side is the culprit for balance.
My outer lugs were torn up by them somehow. They claimed it was the dump trailer but that would be impossible.
Yep all four rear drives are out in one way or another. Bet the front are too. I don't think it's even worth checking those at this point. I don't like running mismatches anyway.
Conclusion: cheap farmers never bothered to balance the drives and let it sit too long in the same spot.
Sigh.
Oh well. It is what it is. At least now I know there probably isn't anything wrong with my chassis.
I'm not gonna bother checking the front drive because I'm not gonna run mismatch.
The only thing to decide is whether to go for all new drive wheels while they're being changed or let them mount to these ugly steelies to save $.
