Every time I go into that area and keep getting cut off I wonder how many of those douchebags were just on CNN or MSNBC or FOX news. They're all one and the same.
It's the beltway of the nation's capitol so at least some of them must be pundits.
Makes me want my death wish push bar even more. The spikier and more terrifying to cars the better.
Got a new POV with the GoPro for y'ins. It's less than 2 minutes so pretty tolerable. I'm only doing 1080p lately because of the ambient temperatures and battery issues, so apologies for the low quality.
1080p with stabilization on gives me basically 1 percent per minute of recording compared to 4K which is fractional.
IOW a fresh battery gave me a little over 100 minutes of recording even in this heat.
Recording in 4K would have shut the camera down.
Pretty clear picture, Looks good!
I have an 85" 4K in the living room and at 3" away and even 3 feet away everything looks like crap. You gotta be at least 10 feet from it for anything to look decent. Normal viewing position is 22 feet away and it pops beautifully.
4K native looks good on my 60 inch.
The older Blu-ray look acceptable but not great and DVDs basically look like VHS.
Isn't there like a safety lane that you have to pass through prior to exiting the facility? They check everything to be sure the chassis is road ready and the can is secure. Or is that only some ports that do that?
I didn't know that was a loss to you, I thought that you just saw it on the line and took the picture.
It's just a drive through shop and you can't use it when it's not open.
It looks like above ground pools in your area are the norm. Is that because they are easier to 'winterize', than an in-ground pool? Winterizing is something I've never had to do for any pool either owned by me or my customers. Most are used year round here.
I like the depth of the properties. It makes it easy to put out buildings on them while not encroaching on the main structure living area.
I many times wish that I wasn't 'under the gun' to buy what I did up here. I should have bought vacant land, put a double wide in the back area and built a house to my specs, then built a detached shop out back away from the house. Since I've moved in here, prices for land have tripled and existing homes are up at least 2 1/2 times what they were in 2016.
I don't know what happens when pool water freezes.
Ice expands in all directions with seemingly unlimited force. If the sides of the pool are tapered outward like a drink cup, the ice will scoot upwards as it expands, rather than stay put & destroy the concrete, or the structure of an above-ground pool.
Long before the internet, I saw a thing on TV where they made a solid steel ball about the size of a bowling ball, with a hollow center the size of a baseball.
They filled the center with water, through a threaded hole, then corked it with a long bolt.
At first they heated it up to like 300 F° and determined it was capable of holding back the steam pressure.
Then they put it in a restaurant style walk-in freezer and put it in a protective cage like they use for inflating truck tires.
When the water core froze, the steel ball exploded. 😳
I never saw a pool freeze, mainly because I would never reside in that type of environment.
As we were always taught, water is the most powerful force on Earth.
