No GoPro action today. Had a pickup appointment to meet and didn't think I'd have time to dick around with the camera and still make it on time.
Also temporarily out of ideas for filming.
Bobtailed for a pickup load back to the rail.
It's stupid low gross rev but it's only about 6 hours and still profitable, just not very much.
I'm kind of in something is better than nothing mode, and that's exactly where they want us. We don't have the upper hand like during covid.
I could go company to earn more but with higher expectations. I'm not sure what I could do with my day cab to earn more elsewhere even with my authority. It didn't seem to work for me when money flowed like water so it would probably be worse now.
Anyways when I was going down the VA scale was full green to platform everyone, but they turned the light off until I was under it and then gave me the green to pass through. That was kind of neat. They know me and my truck. The scale master said as much.
Got another new dashcam for the Mack. This one is mounted to the rear window and has 3 cameras on it. One full front that adjusts up and down and two on the sides that adjusted up and down and rotate a swivel to be forward or backwards.
It's not as high quality as my front camera, which was pretty pricey. This one was fairly inexpensive and records 1080p.
I'm looking at getting all around coverage like these fleets have. This is sort of an initiation into it.
Just got it and put it in this evening, saved some sample videos while parked since it auto records as soon as it gets power, but don't know if it'll hold up to the bouncing.
Looks promising, but I'm keeping the box.
I need a dual cigarette port adapter to run both dashcams with everything else in the truck, and I have an Upper Marlboro MD run tomorrow so I'll charge my phone and tablet with a portable battery pack to get through until the adapter arrives.
The Upper Marlboro run will be a pretty good test of this setup. The DC beltway can get gnarly at times.
Going through some of the footage. TBH the angles really aren't super helpful with a trailer on. I knew you'd see a lot less but wasn't 100% sure if it would still be useful.
It's NEAT but I'm debating on sending it back.
I think if I'm going to have full camera coverage that helps as much as possible, I need to do it right and mount weatherproof ones on the outside.
I suppose I could put this camera in the front of the pickup. It came with an extra adhesive mount.
I have seen some trucks that have cameras mounted on each mirror pointing rearward and then one dashcam pointing forward. I think they are one integrated system but even still if a truck had those three cams and they were independent there would still be SD cards for each one. No?
The only problems would be cord length and a place to plug them in.
I'm not sure how they do it but this cheap one creates a separate folder for each camera and stores the files separately on the same card.
IOW there's a Front, Left, Right, and Rear folder.
When I was operating near a few of Amazons DC's, I would see their gray Shakers with no mirrors at all. There were just cameras on the sides of the cab and the image was projected to a screen on the dash. I'm not sure they still use this set up as I've not seen it since.
I've seen a few like that.
I can see having view cameras as an extra but definitely not as the only.
I somehow just can't trust technology to give me the same view as I can see through experienced eyes. A simple millisecond glance in the mirror can give you a ton of information if you know what you're looking for. Even a glare on the screen can lead you to think you saw something that really wasn't there.
Yeah exactly. And it's 100% real time not based on a feed that might have even the tiniest of delays.
