Electric Chicken
That impact gun really is a cure for ED though. I'm just sayin'.
That’s what I askedAre they hub-piloted?????
I would assume so. I'm dumb though.Are they hub-piloted?????
I thought I answered.That’s what I asked
The advice that you were given to get the whole back end jacked up and run it can show off center and bouncing very clearly. My tire shop has done that for me in the past. Just make sure front tires are well blocked.Maybe I should rotate them while I'm at it and see if it changes anything. Still need to get me a shiny brand new accessory bottle jack though.
10-4. Don't worry I've forgotten the bill already. Took some therapy but I did it.The advice that you were given to get the whole back end jacked up and run it can show off center and bouncing very clearly. My tire shop has done that for me in the past. Just make sure front tires are well blocked.
I couldn't work this truck until I had this issue figured out...You could be right. It really boils down to $ and I'm not gonna let it stop me from putting it to work.
Damn don't ever work for Schneider then.I couldn't work this truck until I had this issue figured out...
Let's try again.I would assume so. I'm dumb though.
Lol 1.Let's try again.
1 piece or 2 piece lugnuts??
Not that I saw, which is it?I thought I answered.
I don't know enough to answer. I haven't had them off, or looked at anything but condition. I know they're not those spoked ones with the lugs on the ring. They're modern. How they're centered I dunno.Not that I saw, which is it?
You answered when you said one piece lugnut that is if you tell the difference, do they look like this;I don't know enough to answer. I haven't had them off, or looked at anything but condition. I know they're not those spoked ones with the lugs on the ring. They're modern. How they're centered I dunno.
But you're a O-O now.Damn don't ever work for Schneider then.
I don't have 5,000+ for tires and wheels if that's what's called for. I could spend it if I was already hooked on and saw it coming down the pipe.But you're a O-O now.
Now is the time to not be like them and fix the issues when they come up.
Otherwise your the pumpkin on smaller scale,putting stuff off....
And that was your constant complaint with them..
Just say'n..
I admire what you're doing,reminds me of myself when I bought my 1st truck when I was 20.
