The way I'm imagining it, I'd be drilling holes in my roof. So I'm reluctant to do that. I have this fantasy where I'm driving around a dark trailer lot with stadium lighting all around me but I'm not sure if glare would be an issue.For the quietness and ease of working at night, it's a small effort to put forth.
Bro got the spirit.
Also this is the new dashcam. Same make & model I put in the Honda. Old one was gradually taking longer and longer to start up, to where I'd make significant progress down the road before it would record. Not really a good thing for a dashcam. I plan to put it (the old one) in the pickup since it sees almost no use anymore. Hopefully it has enough life in it to be worth that much, since the footage quality itself is quite good.
Bro got the spirit.
On our old shunt trucks we had LED roof mounted lights for that very reason. These were more like the small back up lights but mounted forward on the roof. they were great for finding trailers and pissing people off when you forgot to turn them off.I'm considering putting some forward floods like my rear mounted Rigids on the roof on an individual switch for scouting empty trailers in these unlit lots. It's one thing to see where you're going and another to see vertical numbers high up on the corner post.
I most likely won't though due to the effort involved.
Yeap that's my inspiration behind it.On our old shunt trucks we had LED roof mounted lights for that very reason. These were more like the small back up lights but mounted forward on the roof. they were great for finding trailers and pissing people off when you forgot to turn them off.
Probably not.Is that even legal?
I didn't have to remove the wheel to replace the stalk. I'm not sure if the canceling cam is or could have been loose or how any of that part works. But it did click the lever itself on and off, it just didn't blink the left signal unless I held it all the way down (towards me). Sometimes it would come and go but eventually was more go than come.The stalk screws into a plate, which is affixed to the main mounting plate under the steering wheel itself. On that main plate is the canceling cam. Could that main plate have a screw loose or something?
Shooting in the dark here. It's been many years since I had the wheel of a big truck off.
To be fair the new stock isn't a self canceler. It's manual like the original to the truck. I had "upgraded" after the original wore out.And with the new stalk it works correctly? Strange. It sounded like connectivity problem the way you described it.
Yeah that would definitely suck. New one seemed fine all day though so hopefully it's just the stalk.Kinda nice the features it has.
So, if the problem persists, you can count on it being in the truck side of the 12 point plug harness. That would suck.
That's good. Trucks should not have self-cancelling turn signals IMO.To be fair the new stock isn't a self canceler. It's manual like the original to the truck. I had "upgraded" after the original wore out.
But yeah I'm thinking now, it's not the cancel or the physical click either. There might be an internal short.
