Did it have it jammed or did you just see it.Had a piece of zip tie stuck in my 5th wheel jaws. So I got one of those wirey grabber things I remembered my dad having in his auto garage and playing with when I was a kid. Since it's 2 feet long, I was able to stand on a tire and the frame and reach down in without fear of falling or leaning into the nasty ass plate.
I just saw it. Wanted to get it before it caused chaos, if it even could.Did it have it jammed or did you just see it.
Our mechanic should get one of those.Had a piece of zip tie stuck in my 5th wheel jaws. So I got one of those wirey grabber things I remembered my dad having in his auto garage and playing with when I was a kid. Since it's 2 feet long, I was able to stand on a tire and the frame and reach down in without fear of falling or leaning into the nasty ass plate.
Some idiot was greasing the glad hands with that stuff on purpose and it was contaminating everything.Our mechanic should get one of those.
Fucking guy put his boot on the fifth wheel to tilt it and tracked grease across the catwalk. Our airlines are bundled in a hard plastic wrap and drag across the catwalk. Had I Not cleaned off all the grease it would have be all over the airlines and therefore all over my pants.
I, like you, deal with a lot of different trailers/chassis and have seen that.Some idiot was greasing the glad hands with that stuff on purpose and it was contaminating everything.
WOW! We used Arctic Fox heaters back in the 80's. I didn't think anyone used them anymore. It seems most fuel heaters are electric.In other news, I cleared enough crud to find out what that weird plated thing with the two posts is on my secondhand fuel tank.
It's an Arctic Fox fuel heater that uses coolant to unfreeze the fuel in the tank. I don't think the idea is to get it started that way but to keep the truck running and let the warm coolant stop it from freezing in the first place. So those ports never needed welded in the first place, because it's a sealed system.
Anyway, that gave me the clue I needed to find and order the OEM gasket. Because mine leaks. And the make a gasket I attempted didn't work either.
The gasket is $ but pretty commonly available. Since it's formed to the correct dimensions and presumably of the correct cork material to be diesel compatible I spent the coin and ordered it today.
I don't lose a lot but there's splash related seepage that works its way out and runs down my tank. I don't like that.
I was similarly surprised to see that's what it is. I had thoughts like maybe it was actually a hydraulic tank or something.WOW! We used Arctic Fox heaters back in the 80's. I didn't think anyone used them anymore. It seems most fuel heaters are electric.
Usually hydraulic tanks are a different shape with a different, smaller filler cap.I was similarly surprised to see that's what it is. I had thoughts like maybe it was actually a hydraulic tank or something.
I've seen some that are basically just another fuel tank.Usually hydraulic tanks are a different shape with a different, smaller filler cap.
That truck was most likely used in rock/sand/coal hauling.I've seen some that are basically just another fuel tank.
They make all kinds though. The LTL had a big black plastic square tank mounted up behind the cab.
My truck? It was a farm truck and ran a belt trailer. Or whatever those are called.That truck was most likely used in rock/sand/coal hauling.
I have no idea but I saw it and it simultaneously dumped and had a roller to get the stuff out.IIRC they were called live bottoms. But, it's been a while.
That's because hot Liberal chicks don't exist.Didn't get accosted by any hot liberal chicks
